How to get position vertex of a polygon?
m09366023695
m09366023695
I how polygons and I want to get positions of vertexes(red cycles) to calculate length of each side (blue lines).
grobnik
Hi @m09366023695 you can try with
Sub Example_Coordinates()
Dim Selection As AcadSelectionSet
Dim Poly As AcadLWPolyline
Dim Obj As AcadEntity
Dim Bound As Double
'Makes a selectionset.
On Error Resume Next
   Set Selection = ThisDrawing.SelectionSets.Item("Select polyline.")
If Err Then
   Set Selection = ThisDrawing.SelectionSets.Add("Select polyline.")
   Err.Clear
Else
   Selection.Clear
'Select the polyline.
Selection.SelectOnScreen
For Each Obj In Selection
   If Obj.ObjectName = "AcDbPolyline" Then
           Set Poly = Obj
           Bound = UBound(Poly.Coordinates)
           x = 0
           y = 1
           For i = 0 To Bound / 2
               Debug.Print "X= " & Poly.Coordinates(x) & "  Y= " & Poly.Coordinates(y)
               If Err Then Err.Clear
               x = x + 2
               y = y + 2
           Next
Next Obj
End Sub
On immediate window you will found each vertex coordinates X, Y of course not Z.
grobnik
Hi @m09366023695 here below a tentative to reach segment length. Probably there will be a best way but simply I'm drawing a line from each vertex to the next retrieving the line length and in the same time polygon segment length.
Dim Bound As Double
Dim MyStartCoords(0 To 2) As Double
Dim MyEndCoords(0 To 2) As Double
Dim MyLine As AcadLine
Dim x As Integer
Dim y As Integer
  ' Set Selection = This785Drawing.SelectionSets.Item("Select polyline.")
'If Err Then
   'Set Selection = ThisDrawing.SelectionSets.Add("Select polyline.")
  ' Err.Clear
'Else
 '  Selection.Clear
'End If
'Selection.SelectOnScreen
For Each Obj In ThisDrawing.ModelSpace
'For Each Obj In Selection
           Set Poly = Obj
           x = 0
           y = 1
           For I = 0 To Bound / 2
                    MyStartCoords(0) = Poly.Coordinates(x)
                    MyStartCoords(1) = Poly.Coordinates(y)
                    MyStartCoords(2) = 0
                    MyEndCoords(0) = Poly.Coordinates(x + 2)
                    MyEndCoords(1) = Poly.Coordinates(y + 2)
                    MyEndCoords(2) = 0
               Set MyLine = ThisDrawing.ModelSpace.AddLine(MyStartCoords, MyEndCoords)
               MyLenght = MyLine.Length
               'Debug.Print "Vertex #  " & I + 1 & "  X= " & Poly.Coordinates(x) & "  Y= " & Poly.Coordinates(y) & " Lenght " & MyLenght
               x = x + 2
               y = y + 2
               MyLine.Delete
           Next
                    MyStartCoords(0) = Poly.Coordinates(Bound - 1)
                    MyStartCoords(1) = Poly.Coordinates(Bound)
                    MyEndCoords(0) = Poly.Coordinates(0)
                    MyEndCoords(1) = Poly.Coordinates(1)
                    MyEndCoords(2) = 0
                    Set MyLine = Null
                    Debug.Print " Lenght " & MyLenght
                    MyLine.Delete
Next Obj
End Sub
