How to get parrameter from dynamic block
danijel.radenkovic
danijel.radenkovic
Hello to all,
I have created an dynamic block. Block consist of Two Points, one Linear Parameter and an Dimensional Constraint between them. Using "Stretch" action, I can change distance between points by moving one of the points, so dimensional constraint updates immediately. My question: How to get the value of the linear dimension inside the block?
Any help is very appreciated.
Danijel
Inventor 2018/Windows 10 x64
If this information was helpful, please consider marking it as an Accepted Solution by using the Accept as Solution. Kudos are also gladly accepted.
use  GetDynamicBlockProperties() method of the BlockReference object
for instance, the following function will return the value of the passed block reference dynamic property named after passed propName parameter
Function GetPropertyValue(objBlockRef As AcadBlockReference, propName As String) As Variant
    Dim iProp As Long
    Dim dybprop As Variant
    If objBlockRef.IsDynamicBlock Then '<--| if the passed block reference is a dynamic block one
        dybprop = objBlockRef.GetDynamicBlockProperties '<--| get its dynamic properties
        For iProp = LBound(dybprop) To UBound(dybprop) '<--| iterate through them properties
            With dybprop(iProp)
                If .PropertyName = propName Then '<--| if the current property matches the passed name
                    GetPropertyValue = .Value '<--| return ist value
                    Exit Function
            End With
        Next
End Function
that you could use as follows:
Sub main()
    Dim returnBlck As AcadBlockReference
    ' code to have the user select the block reference to query property of
    MsgBox GetPropertyValue(returnBlck, "SW") '
End Sub
danijel.radenkovic
That's I was looking for.
Thank you!
