How to end Excel from VBA
Message 1 of 9
I'm having a hell of time trying to close down excel from my vba program.
My operating system is Windows 98.
Here is the code:
Private Sub Excel_Running_Check()
Dim excelApp As Excel.Application
On Error Resume Next
Err.Clear
Set excelApp = GetObject(, "excel.application")
If Err <> 0 Then
Err.Clear
Else
excelApp.DisplayAlerts = False
excelApp.ActiveWorkbook.Close
excelApp.Quit
Set excelApp = Nothing
End Sub
The idea for this sub is to check for a running instance of excel. If it
exists then close it down before opening up another instance of excel. The
problem is that excel still remains memory resident. I verify this by using
ctrl-alt-del to open the task manager and notice that excel is still
running. The only way I can get excel to stop running is to close down my
application with the End function. I've seen similar posts all over the
internet but I haven't found an answer to it yet. The fact that excel is
not released from memory causes problems when reopening excel through my
program. Subsequent intances of spreadsheets are not formatted
programatically as is intended through my code. Several instances of excel
remain running in task manager. Please help.
Replies (8)
Message 2 of 9
This is a known problem with Excel. I suspect that you havn't shown all of
your code, but the rule here is to clear up all your object variables in the
reverse of the hierarchical order that you derived them. For example, you
start with an application object, then use it to create a workbook object,
and then use that object to create a sheet object. Before you close the app,
you need to set to nothing, first the sheet object and then the workbook
object. Then you can deal with the app object.
Ed
"Gordon Reichhardt" wrote in message
news:66D7FF33CB39611744607A55E9E7CD31@in.WebX.maYIadrTaRb...
> Here is the code:
> Err.Clear
> If Err <> 0 Then
> Err.Clear
> Else
> excelApp.Quit
> End Sub
The
using
my
excel
Message 3 of 9
I have the same behaviour with Visual Lisp see:
customization: Excel Quit: new behaviour (04/29/03)
I am searching a solution.
Marco
1) if I run this function the Excel app is closed correctly
but if I activate the lines with ";<<" Excel is not closed
completely and in task manager remain a instance, why?
2) is it a method to find any "non-released" objects?
; A2K2 - SDI = 1 - Excel not running
(defun C:XlTest ( )
(vl-load-com)
(setq
*ExcelApp* (vlax-get-or-create-object "Excel.Application")
*ActiveWbk*
(vlax-invoke-method
(vlax-get-property *ExcelApp* 'WorkBooks) 'Add
*ActiveSht* (vlax-get-property *ExcelApp* 'ActiveSheet)
*ActiveCls* (vlax-get-property *ActiveSht* 'Cells)
(vla-put-visible *ExcelApp* 1)
(setq
SttCll (vlax-variant-value
(vlax-get-property
*ActiveCls* 'Item
(vlax-make-variant 4) (vlax-make-variant 4)
EndCll (vlax-variant-value
(vlax-get-property
*ActiveCls* 'Item
(vlax-make-variant 4) (vlax-make-variant 10)
; RngObj (vlax-get-property *ActiveSht* 'Range SttCll EndCll);<<
(vlax-release-object SttCll)
(vlax-release-object EndCll)
; (vlax-release-object RngObj) ;<<
(setq RngObj nil SttCll nil EndCll nil)
(vlax-release-object *ActiveCls*)
(vlax-release-object *ActiveSht*)
(vlax-invoke-method *ActiveWbk* 'Close :vlax-False)
(vlax-release-object *ActiveWbk*)
(vlax-invoke-method *ExcelApp* 'QUIT)
(vlax-release-object *ExcelApp*)
(setq
*ExcelApp* nil *ActiveWbk* nil *ActiveSht* nil *ActiveCls* nil
(gc)
"Ed Jobe" ha scritto nel messaggio
news:8483292FF87D571DBF50F70EDED0016D@in.WebX.maYIadrTaRb...
the
app,
> Ed
Message 4 of 9
I have has the same problem but finally found a solution!
The problem fore me would occur when I was formatting the cells in the worksheet.
Avoid using .Select. ActiveSheet, ActiveCell, With, .Range, and .Select.
Instead use the object reference.
For example instead of :
Range("A1:A3").Font.Bold = True
try:
objSheet.Range("A1:A3").Font.Bold = True
Instead of
'With objSheet.Rows("4")
.HorizontalAlignment = xlCenter
.VerticalAlignment = xlCenter
.WrapText = True
.Orientation = 0
.AddIndent = False
.IndentLevel = 0
.ShrinkToFit = False
.MergeCells = False
End With
try:
objSheet.Rows("4").HorizontalAlignment = xlCenter
objSheet.Rows("4").VerticalAlignment = xlCenter
objSheet.Rows("4").WrapText = True
objSheet.Rows("4").Orientation = 0
objSheet.Rows("4").AddIndent = False
objSheet.Rows("4").IndentLevel = 0
objSheet.Rows("4").ShrinkToFit = False
objSheet.Rows("4").MergeCells = False
When you're ready to close Excel you will want to use
objExcel.quit
set objExcel = nothing
It works great for me.
Hope this helps
Message 5 of 9
As pointed out it is a long standing issue. Try this as a long standing solution:
http://support.microsoft.com/default.aspx?scid=kb;en-us;132535
Good luck,
Bob Coward
CADS, Inc
800-366-0946
bcoward@mindspring.com
Message 6 of 9
Marc...
I am trying to write a piece of LISP code to answer an "alert box" that pops up when I load a linked Excel file...
I found your email in a LISP program (MsXUtl01.LSP)…you look to be an Excel-AutoCAD expert, so I am asking you this question!! (Thanks!)
I have a problem I’m working on…I need to “translate” a line of VBA code into its LISP equivalent…
Set xlbook = xlapp.Workbooks.Open(path & "\" & dwgname & "-" & "KeyNotes Data Main.xls", UpdateLinks:=3)
This line of VBA code opens an Excel file and answers “yes” to an alert asking “Do you want to Update Links?” … “Yes / No”…
Here’s what I have so far for my LISP…and it works, except that the program stops when the alert is displayed asking the user to indicate his Link Updating preference…
((setq excelsession (vlax-get-or-create-object "Excel.Application"))
(vlax-invoke-method
(vlax-get-property excelsession 'WorkBooks)
'Open fn ßHOW DO I “FEED” A RESPONSE TO EXCEL WHEN IT ASKS IF I WANT TO UPDATE LINKS??? (“YES”)
(if (= (strcase dmode) "SHOW")
(vla-put-visible excelsession 1)
(vla-put-visible excelsession 0)
Any help or suggestion will be greatly appreciated!
Pete
Message 7 of 9
The Microsoft Knowledge Base article referred to seems to apply to FoxPro...
APPLIES TO
• Microsoft Visual FoxPro 3.0 Standard Edition
• Microsoft Visual FoxPro 5.0 Standard Edition
• Microsoft Visual FoxPro 5.0a
• Microsoft Visual FoxPro 6.0 Professional Edition
Is there a VBA specific solution?
Thanks!
Message 8 of 9
I have to tryed to rewrite this code on pure VBA with using
of API functions see my example
Make sure that in VBEditor ->Tools->Options->General
was checked "Break on Unhandled Errors" button
Feel free to adapt it to your suit
Option Explicit
Private Declare Sub Sleep Lib "kernel32" (ByVal dwMilliseconds As Long)
Private Declare Function FindWindow Lib "user32" Alias "FindWindowA" (ByVal lpClassName As String, ByVal lpWindowName As String) As Long
Private Declare Function SendMessage Lib "user32" Alias "SendMessageA" (ByVal hwnd As Long, ByVal wMsg As Long, ByVal wParam As Integer, ByVal lParam As Any) As Long
Const WT_SLEEP = 2500
Const WM_CLOSE = &H10
Const WM_ACTIVATEAPP = &H1C
Const WM_USER = 1024
Const gcClassnameMSExcel = "XLMAIN"
Sub TestExcelQuit()
Dim xlApp As Object
Dim xlBook As Object
Dim xlSheet As Object
Dim hwnd As Long
Dim WhatD As Long
Set xlApp = Nothing
Set xlApp = GetObject(, "Excel.Application")
If Err.Number 0 Then 'read this line as If Err.Number not equal zero
'because this symbol not shown correctly in this code
'I don't know why
Set xlApp = CreateObject("Excel.Application")
Err.Clear
On Error GoTo Err_Control
MsgBox "Sleep 2.5 seconds"
Set xlBook = xlApp.Workbooks.Add
Set xlSheet = xlBook.worksheets(1)
xlSheet.Application.Visible = True
Sleep WT_SLEEP ' pause 2.5 sec
xlBook.Close Savechanges:=False
Set xlSheet = Nothing
Set xlBook = Nothing
hwnd = FindWindow(gcClassnameMSExcel, 0)
Do While hwnd > 0
'WhatD = SendMessage(hwnd, WM_USER + 18, 0, ByVal 0&) ' Microsoft Excel 95
WhatD = SendMessage(hwnd, WM_ACTIVATEAPP, 0, ByVal 0&) ' Microsoft Office 2000 or Microsoft Office XP
'Set xlApp = GetObject(, "Excel.Application")
xlApp.Quit
Loop
Set xlApp = Nothing
Err_Control:
If Err Then
MsgBox Err.Description
Set xlApp = Nothing
End Sub
Fatty
~'J'~ Message was edited by: Fatty
Message 9 of 9
Mikko
http://www.devcity.net/Articles/239/1/article.aspx
