how to convert line to closed polyline?
user draw the house using line command
i want convert every house to colsed polyline,so they will be an object,how
to?
thanks
If you are using AutoCADMap2000, there is an option to do that
Map menu -> Topology -> Create closed polylines
I've got the spanish version so I've tried totranslate the names of the
options and menus. May be the names could be a little different, but the
option to do what you want is in AutoCADMap. Take a look to the on-line
help.
I hope this helps
Bye
Manuel
"luochen" escribió en el mensaje
news:EC0BB56441A0568FBB9C8FB1F66CFC84@in.WebX.maYIadrTaRb...
object,how
> to?
> thanks
thanks
but if i just with autocad,can i build a macro to do this?
"Manuel Rivero" wrote in message
news:0510FA947AC83E8901B043A0E984384E@in.WebX.maYIadrTaRb...
> help.
> I hope this helps
> Bye
> Manuel
> object,how
> > to?
> > thanks
HI
i hope this could help you
to create a polyliyne from line use the commande:
BPOLY (enter)
choose (pick ...)
then you pick into the areas u want to transform and after this (enter)
i'm trying to convert polylines to polygones that i can transforom them to arcview
do you have any idea how to convert to polygones in autocadmap?
"luochen" wrote in message
object,how
> to?
> thanks
Express Tools -> Modify -> Multiple Pedit -> (select all) -> (convert
lines... yes) -> join -> fuzz=0 -> Close.
Fekete Csaba
teodolit@teodolit.hu
