How to Convert Arc into Serie of lines or Polylines.
01:57 AM
I have a problem in my project, i need create the a drawing with severals acadobject(Lines,Polylines and Arcs) that i obtained from other drawing, well i have a Gerber Cutter Machine and this machine doesn´t accept Arcs the machine only accept Polyline, not curves, if i convert the arc with pedit into polyline the machine send me an error, so i need to create a series of lines and that lines represent the arc, well if some body knows a VBA Code for convert Arc into series of lines or Polylines, please help me or if any body have an idea of how to resolve this problem
I working in Arc Equation the arc is a section of circle, i want to use numerical integration method for find points in to arc. Like Newton Raphson, Simpson 3/8 but is very complex..
Or used
Chords were used extensively in the early development of trigonometry. The first known
trigonometric table, compiled by Hipparchus, tabulated the value of the Chord
function for every 7.5 degrees.
The chord function is defined geometrically as in the picture to the left.
The chord of an angle is the length of the chord between two points on a
unit circle separated by that angle
Im Lost in this issue
Or used
