how to call acad from std. exe?
Message 1 of 17
Hi all,
I have a vba dvb I've been calling from acad with a lisp routine via
vla-runmacro or vl-vbarun
I want to change it to a stand alone .exe
in addition to changing all ThisDrawing references I need to somehow connect
to acad.
but since I'll be calling the exe from within acad (I presume by using
(Startapp) ???) I'm confused about how to connect to acad. I obviously
don't need the usual "on error resume next getobject if err then create
object" that I would use if I was starting the exe from outside of acad. so
what's the proper way to refer to the instance of acad that is calling the
app?
I know this is a stupid question but hey, that's my specialty!
Mark
Replies (16)
Message 2 of 17
Mark Propst wrote:
> so what's the proper way to refer to the instance of
> acad that is calling the app?
You'll need to create an ActiveX executable with one publicly creatable
class. That class should have a property that will accept a reference to
an AcadApplication object.
Using VisualLISP, create an instance of the class and set its
application property passing the return value of (vlax-get-acad-object).
I know that sounds like a lot of effort but it's the only reliable way
to attach to the proper instance of AutoCAD. VB's GetObject is
insufficient for scenarios involving multiple running instances of
AutoCAD.
There are 10 kinds of people. Those who understand binary and those who
don't.
http://code.acadx.com
Message 3 of 17
Hi Mark,
Perhaps it would be easier to answer your question if you stated what you
are trying to accomplish. But on the side, some things you stated are
inconsistent. You stated you wanted a stand alone program, but then you
sound as if you still want it to run in the same process as the current
session of acad. BTW, (startapp) is like using the Shell function, once you
start the app, acad has no control over it.
Ed
"Mark Propst" wrote in message
news:8CF75C8DCA9D38E6E759AA8156D6B42C@in.WebX.maYIadrTaRb...
> Hi all,
connect
> to acad.
so
> app?
> Mark
Message 4 of 17
Thanks Frank,
I'll try that.
Mark
"Frank Oquendo" wrote in message
news:980A78CFEA8EFF9B82938CD27BD09F2C@in.WebX.maYIadrTaRb...
> class.
Message 5 of 17
Hi Ed,
Thanks for responding,
"Ed Jobe" wrote in message
news:F5CD95946C476EC4BFE5795790C7D8A9@in.WebX.maYIadrTaRb...
> Hi Mark,
I just wanted the app to be an .exe so it was compiled so the code wasn't
visible.
you
yeah, I was thinking that startapp or shell would be the two ways I could
think of to fire an .exe file (don't know if there are others)
yeah, i'm not sure the correct terminology, like I say I just wanted to
compile it so I was thinking that meant it was a 'stand alone' .exe.
But yes, the program flow is that i'm in acad and want to use this program
(all it does is draw some symbols, inserting them as blocks with
attributes). It works fine as a dvb but that leaves the source code
visible.
Frank suggested activex exe so maybe that's more the right terminology?
Message 6 of 17
> visible.
You could also compile to dll. The main difference is that the exe will be
an out-of-process server and the dll will be running in acad's process which
is usually faster. You could use Frank's approach for both. As for calling
the dll, the lisp ng has had some discussions recently on how to do this.
Ed
news:E85B987E2A89D3F771DAB8C5408B25F6@in.WebX.maYIadrTaRb...
> Hi Ed,
> > Hi Mark,
you
> visible.
> you
> visible.
Message 7 of 17
Hi Ed,
I need a little clarification
news:050ED5110F59991CA21502A8371C82FF@in.WebX.maYIadrTaRb...
is that *any* exe? ie both a standard Exe and an Activex exe would be out
of process?
> is usually faster.
that's what I would prefer
you mean I can create Either and activex.exe or an activex.dll and make the
classes etc that frank mentioned and it would work the same?
but the exe would be out of process where the dll would be in process???
> As for calling
yes, I was playing with that a bit last week with limited success. I'll
have to try again if I get this conversion working.
Thanks again for your info.
Mark
Message 8 of 17
>> will be an out-of-process server
> be out of process?
Any executable will be out-of-process. However, you can minimize the
performance hit by compiling all code that will be interacting with
AutoCAD into a DLL. Once you've conencted to AutoCAD, you can load the
DLL into AutoCAD's process space by using GetInterfaceObject. Then
manipulate the created object from within your executable.
> make the classes etc that frank mentioned and it would work the same?
> process???
That's correct.
don't.
Message 9 of 17
sorry for being so dense, but...
so what would be the advantage of creating an activex.exe *and* an
activex.dll rather than just doing everything in the .dll?
the program flow is merely calling sub main.
sub main calls form.show
form_initialize creates a weldsymbol class instance
the various checkboxes etc in the form set class properties,
then the command button calls the class.draw method which inserts or creates
the appropriate block and attributes.
so the only interaction with autocad is hiding the form and picking a point,
once all the choices have been selected in the form. then that's the end of
the program.
Could all of that not be in the dll, eliminating the exe altogether?
So far the only dlls Ive made are subs and classes only - (toolbox
utilities).
whenever I have created a project with a form I've been making a standard
exe. so I'm not sure if there are issues with dll and a form class.
Thanks as always for your helpful suggestions,.
Mark
all code is then an interaction between
news:E9043236B1CF438511F079A5CDAA5778@in.WebX.maYIadrTaRb...
Message 10 of 17
Actually, you wouldn't do both.
The ActiveX executable would be the way to go if you wanted everything
inside the executable as a public class would be the only way for your
app to interact with AutoCAD.
The DLL is the right solution if you don't mind compartmentalizing your
application or want to increase its performance.
don't.
Message 11 of 17
BTW, you can't just code a DLL because you'll still need a client
application to make use of it. You can do that with VBA but it's not a
very secure solution.
don't.
Message 12 of 17
so in this sentence:
"... you can't just code a DLL because you'll still need a client
application to make use of it."
the word "client" refers to something different than just calling a dll from
lisp?
as in this pseudocode idea of how to call a dll from lisp
(defun InvokeDll(dllName dllMethod / ac res res2)
(setq ac (vlax-get-acad-object))
(setq res(vla-GetInterfaceObject ac dllname))
(setq res2 (vlax-invoke-method res dllMethod))
(vlax-release-object res)
(vlax-release-object ac)
res2
that function (just pseudocode) probably wouldn't work, it's just my way of
trying to figure out how to call a dll from lisp pasted together from a few
recent posts. I haven't tried it yet.
like I say it's more like pseudocode...i'm not sure what I need to change
yet to make it work as a callable function.
but is that what you mean by "client" or is it something different?
news:DE67F13EA570CBDDD9E7C4BCADD5A6BB@in.WebX.maYIadrTaRb...
> don't.
Message 13 of 17
> dll from lisp?
Not at all... A client can be written in any language that supports
ActiveX, including VisualLISP.
But if you already know VB and are new to LISP, I'd suggest sticking to
what you know if you have any sort of deadline on this project.
don't.
Message 14 of 17
news:58723241BA8FBB946D562F96764DAF70@in.WebX.maYIadrTaRb...
well, I've been mangling lisp for 10 years more than I have been misusing
vb. 🙂
but..., this is the first I've tried calling a dll from lisp.
I started this project as a vba inside autocad.
It is functioning ok when called from lisp with vl-vbarun
(because vla-runmacro won't allow me to hide the form and pick a point).
Now I wanted to turn the .dvb file into a compiled type file. (from your
posts, either an activex.exe or and activex.dll)
(from many posts i've read I thought the .dll was the way to go because
everyone mentions the performance issue, now I need to research the
activex.exe methodology because you mentioned, if I don't mind
"Compartmentalizing" the app. unfortunately I don't understand what that
means cause I'm not up on the details of an activex.exe interacting with
acad. so I don't know whether I "should" mind "compartmentalizing" or not!
obviously I've got a lot of research to do.
If you think of this app as a simple form with a command button on it, the
only action the entire app does (other than set some parameters for the
inserted block) is to have the user pick a point, and then insert a block at
that point, when the user clicks the "InsertBlock" button. so it's a
pathetically simple application - the only other thing it does is decide
which block to insert and if it doesn't exist, it creates it- big deal!
So in that context, would you recommend an activex.exe or and activex.dll.?
and in terms of the "calling client":
as I understand it, there is no possibility of running a vb or vba app in
autocad without the calling client being a lisp function. Is that
incorrect?
so....
would I make a sub that called the form and then run the sub with
vl-vbarun(just like I'm doing now with the dvb file?) or would I use a lisp
construct similar to the one I mentioned re: calling a .dll? and then
invoking the sub(method) with the lisp syntax (once I get it figured out
correctly)
thanks, as always, for your help
(sorry if I'm being incredibly obtuse here...as opposed to just my normal
obtusosity) 🙂
Mark
Message 15 of 17
> your posts, either an activex.exe or and activex.dll)
A DVB cannot produce either type of file. You'll have to port the code
to Visual Basic, not VBA if you want an EXE or a DLL.
> because everyone mentions the performance issue, now I need to
> research the activex.exe methodology because you mentioned, if I
> don't mind "Compartmentalizing" the app. unfortunately I don't
> understand what that means cause I'm not up on the details of an
> activex.exe interacting with acad. so I don't know whether I "should"
> mind "compartmentalizing" or not! obviously I've got a lot of
> research to do.
Only go with the ActiveX executable if a DLL is not desirable.
> it, the only action the entire app does (other than set some
> parameters for the inserted block) is to have the user pick a point,
> and then insert a block at that point, when the user clicks the
> "InsertBlock" button. so it's a pathetically simple application - the
> only other thing it does is decide which block to insert and if it
> activex.dll.?
DLL.
> app in autocad without the calling client being a lisp function. Is
> that incorrect?
Yes, that is incorrect. You can also use VBA to create your client. The
DVB will contain only the code necessary to create an instance of your
class so one Public Sub is all you'd need.
> normal obtusosity) 🙂
As if I didn't pester folks around just as much five years ago. 😉
don't.
Message 16 of 17
news:B863230A3BB594254533BEC622452D9D@in.WebX.maYIadrTaRb...
i *do* realize that much, that's what I meant.
why would it be not desirable?
> DLL.
cool.
> > that incorrect?
but I can't call the vba dvb without using a lisp function to call it,
that's what I meant in the sentence above.
is that not correct?
so ultimately the lisp is the calling client, is it not?
a lisp client calling a vba client, calling a dll server????
or just eliminate the middle man and have the lisp call the dll with invoke
method
or am i missing something yet again (yeah, I know, I'm missing a whole lot
of somethings)
hmm, I don't remember that!
Thanks again,
Mark
Message 17 of 17
Hi Mark,
How did you get on with this? I was away last week and it's taken me until today (Thursday!!) to catch up on all my emails and the discussion group postings and still try and fit some real work in somewhere 😉 so I'm sorry I'm only getting to see your question now.
I can see Ed and Frank have provided you with a lot of info and maybe you've achieved what you were trying to accomplish by now. My interest is due to the fact that we were spurred by the same requirement, ie I wrote a dvb in VBA and then wanted to protect the source code. I dropped the code into a standalone VB exe but the performance was abysmal (as has been alluded) so instead we ported it to an ActiveX DLL. After some experimentation the result was fairly successful. It's initiated from a button in AutoCAD and doesn't require any lisp.
Let me know if you want more details posted.
Regards
Wayne Ivory
IT Analyst Programmer
Wespine Industries Pty Ltd
