how to Add Region in late binding?
hi, everybody. I want to work in different CAD version, so i use late binding. but there is problem in creating region. Dose anybody knkow how to create rgion in late binding?
Alfred.NESWADBA
Which problem?
Using which code?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
hi,
it is show " Invalid Object Array" when i createed.
dynamic[] circleObj = new dynamic[1];
double[] calpt = new double[3];
calpt[0] = 0; calpt[1] = 0; calpt[2] = 0;
circleObj[0] = AcadDoc.ModelSpace.AddCircle(calpt, 5);
// create region
object[] regionObject;
regionObject = (object[])AcadDoc.ModelSpace.AddRegion(circleObj); //this can't work.
How to do it?
nrjdjjs
I am experiencing the same issue. Were you able to find an answer to this solution? If yes, it would help if you can post the solution that worked for you.
Thank you
I have the same problem as you. If you already have the answer, please let me know. Thank you.
My email: goodfileshare@gmail.com
Alfred.NESWADBA
...using AddRegion with latebinding in VBA?
This code works for me:
Sub Example_AddRegion_LB()
    ' This example creates a region from an arc and a line.
    Dim curves(0 To 1) As Object
    ' Define the arc
    Dim centerPoint(0 To 2) As Double
    Dim radius As Double
    Dim startAngle As Double
    Dim endAngle As Double
    centerPoint(0) = 5#: centerPoint(1) = 3#: centerPoint(2) = 0#
    radius = 2#
    startAngle = 0
    endAngle = 3.141592
    Set curves(0) = ThisDrawing.ModelSpace.AddArc(centerPoint, radius, startAngle, endAngle)
    ' Define the line
    Set curves(1) = ThisDrawing.ModelSpace.AddLine(curves(0).StartPoint, curves(0).EndPoint)
    ' Create the region
    Dim regionObj As Variant
    regionObj = ThisDrawing.ModelSpace.AddRegion(curves)
    ZoomAll
End Sub
It's from the sample in the VBA help, just modified type "AcadEntity" to "Object"
- alfred -
Alfred NESWADBA
double[] squarePt = new double[12];
squarePt[0]=100;
squarePt[11]=1000;
dynamic pLineObj = AcadDoc.ModelSpace.AddPolyline(squarePt);
IDispatch[] ents =
pLineObj
dynamic[] r = AcadDoc.ModelSpace.AddRegion(ents);
dynamic profileRegionObject = (dynamic)(r[0]);
