How in the world do I insert a block and assign values to its attributes as I
values to its attributes as I insert it?
I can't find it anywhere.
any help
joseguia
janitor
Here is what I am using, temporarily, I do not like this method because
there is no method to the numbering in the array, but it works, for this
drawing. If you find a more universal way, aka, a way to call the
attributes by their tag name as opposed to an array number, please let me
know, I will be very grateful. Thanks
This is inserting a block in modelspace, and another block in paperspace.
This is code from VB6.
AppActivate AcadApp.Caption
Set thisdrawing = AcadApp.ActiveDocument
Dim insertionPnt(0 To 2) As Double
' Insert the block
Dim blockRefObj As AcadBlockReference
insertionPnt(0) = 0#: insertionPnt(1) = 0#: insertionPnt(2) = 0
Set blockRefObj = thisdrawing.ModelSpace.InsertBlock(insertionPnt,
"BLOCK", 1#, 1#, 1#, 0)
' Get the attributes for the block reference
Dim varAttributes As Variant
varAttributes = blockRefObj.GetAttributes
' Move the attribute tags and values into a string
Dim strAttributes As String
Dim I As Integer
For I = LBound(varAttributes) To UBound(varAttributes)
strAttributes = strAttributes & " Tag: " &
varAttributes(I).TagString & _
" Value: " & varAttributes(I).TextString & " "
Next
varAttributes(0).TextString = txtlooper.Text
varAttributes(1).TextString = txtneedle.Text
varAttributes(2).TextString = txtjig.Text
varAttributes(3).TextString = txtcage.Text
varAttributes(4).TextString = txtthreadtype.Text
varAttributes(5).TextString = txtdiscnumberreqired.Text
varAttributes(6).TextString = txtdiscpartnumber.Text
varAttributes(7).TextString = txtfabric.Text
varAttributes(8).TextString = txtneedle.Text
varAttributes(9).TextString = txtfabric.Text
varAttributes(10).TextString = txtOALtolerance.Text
varAttributes(11).TextString = txtpinch.Text
varAttributes(12).TextString = txtOAL.Text
varAttributes(13).TextString = txtdiscdia.Text
varAttributes(14).TextString = txtcurrentrev.Text
varAttributes(15).TextString = txtpartnumber.Text
varAttributes(16).TextString = txtfinish.Text
varAttributes(17).TextString = txtflatwidth.Text
varAttributes(18).TextString = txtthreadtype.Text
varAttributes(19).TextString = txtcutlength.Text
varAttributes(20).TextString = txtslitwidth.Text
varAttributes(21).TextString = txtfinishdirection.Text
varAttributes(22).TextString = txtspecialinstructions.Text
varAttributes(23).TextString = txtbagsperbox.Text
varAttributes(24).TextString = txtbagsperbox.Text
' Insert the block
Dim blockRefObj2 As AcadBlockReference
Set blockRefObj2 = thisdrawing.PaperSpace.InsertBlock(insertionPnt,
"TITLEBLOCK", 1#, 1#, 1#, 0)
Dim varAttributes2 As Variant
varAttributes2 = blockRefObj2.GetAttributes
Dim strAttributes2 As String
For I = LBound(varAttributes2) To UBound(varAttributes2)
strAttributes2 = strAttributes2 & " Tag: " &
varAttributes2(I).TagString & _
" Value: " & varAttributes2(I).TextString & " "
Next
varAttributes2(0).TextString = txtpartnumber.Text
varAttributes2(1).TextString = txtconstruction.Text
varAttributes2(2).TextString = txtdimensions.Text
varAttributes2(3).TextString = txttype.Text
varAttributes2(4).TextString = txtOEM.Text
varAttributes2(5).TextString = txtfabric.Text
varAttributes2(6).TextString = txtcurrentrev.Text
varAttributes2(7).TextString = txtrevdate.Text
varAttributes2(8).TextString = txtcurrentrev.Text
varAttributes2(9).TextString = txtrevby.Text
varAttributes2(10).TextString = txtchangesmade.Text
This is almost the way I did it, except where you use an array to assign
your values, I have a procedure that I send the blockreference, the
tagstring and the value I want to set the attribuite to as follows:
Private Sub SetText(objBlockRef As Object, strTag As String, strValue As
String)
On Error GoTo STERR:
Dim i As Integer
Dim objAttributes As Variant
objAttributes = objBlockRef.GetAttributes
For i = 0 To UBound(objAttributes)
'Debug.Print objAttributes(i).TagString
If objAttributes(i).TagString = strTag Then
objAttributes(i).TextString = strValue
Exit For
Next i
'Stop
Exit Sub
STERR:
Err.Raise Err
Exit Sub
End Sub
This way you do not have to know which index is what when you get the
attributes from the blockreference. So now I have something like:
dblInsertPt(0) = 0: dblInsertPt(1) = 0: dblInsertPt(2) = 0
Set objBlockRef = ThisDrawing.ModelSpace.InsertBlock(dblInsertPt,
", 1, 1, 1, 0)
SetText objBlockRef, ,
and so on......
Hope this helps,
Jody Whitfill
"Brad" wrote in message
news:11169335AEFA84D127636DC4158B92C5@in.WebX.maYIadrTaRb...
> ' Insert the block
> Dim I As Integer
> Next
> ' Insert the block
> Next
