How I can modify from VBA to a attibute in a nested block
Hi
Does anyone know how to modify attributes in a nested block.
Luis
wrote in message news:5543140@discussion.autodesk.com...
>Hi
>Thanks
>Luis
Hi Luis,
What exactly are you trying to do?
What have you tried so far? (show code)
What errors / problems are you having?
Strictly speaking there's no such thing as a nested block
To modify an attribute in any block, you just modify the block definition
for that block in the Blocks Collection
I suspect you're really asking how to modify an attribute reference in a
nested block reference but that's just a guess....
to get at any object in any block, iterate the block till you come to the
object you want to modify(in this case I think you're looking for a block
reference)
For Each oEnt in oBlk
If TypeOf oEnt Is AcadBlockReference Then
If oEnt.Name = OneYouLookingFor Then
vAtts = oEnt.GetAttributes
...now you have the attribute references you can mess with
them as you like
...etc
hth
Mark
Hi Mark
I want to modify attribute which are in inserted block.
Regards
Luis
so what did you try, and did it work?
mark
wrote in message news:5548822@discussion.autodesk.com...
Hi Mark
Regards
Luis
Hi Mark
This is what I did so far. I have to explode the block in other to access the attributes.
Regards
Luis
easier to just paste your code here, rather than attach a .doc file
it is not necessary to explode your block to read it's contents
Sub AttExtract()
Dim elem As AcadEntity
Dim Array1 As Variant
Dim entidad As AcadEntity
Dim oBlkRef as AcadBlockReference
Dim oAtt as AcadAttributeReference
Dim iAtt as integer
For Each elem In ThisDrawing.ModelSpace
if TypeOf elem Is AcadBlockReference Then
'you might want to check name also if you just want certain blocks
if elem.Name = FindThisBlockName Then
Set oBlkRef = elem
If oBlkRef.HasAttributes Then
Array1 = oBlkRef.GetAttributes
'**** get the appropiates Array (XY) information that you
need
For iAtt = 0 to Ubound(array1)
Set oAtt = array1(iAtt)
Debug.Print oAtt.Tagstring , oAtt.Textstring
Next iAtt
End if
End if
Next elem
End Sub
hth Mark
wrote in message news:5558937@discussion.autodesk.com...
Hi Mark
Regards
Luis
