how get all intersection point
'i have code to draw circle to all intesection point but not all circle draw to intesection point
what wrong with mycode
Sub test() Dim ss As AcadSelectionSet Dim line As AcadLine, InterCord As Variant Dim cir As AcadCircle, Mtx As AcadMText, fd As Boolean, go As Boolean Set ss = ThisDrawing.SelectionSets.Add(Now) ss.SelectOnScreen For I = 0 To ss.Count - 1 If TypeOf ss.Item(I) Is AcadLine Then Set line = ss.Item(I) line.color = acMagenta line.Update For j = I + 1 To ss.Count - 1 Set line1 = ss.Item(j) line1.color = acRed line1.Update InterCord = line.IntersectWith(line1, acExtendNone) If UBound(InterCord) = 2 Then Debug.Print InterCord(0), InterCord(1), InterCord(2) Set cir = ThisDrawing.ModelSpace.AddCircle(InterCord, 0.2) ThisDrawing.Regen (acActiveViewport) fd = True Else Exit For End If Next j End If Next I End Sub
Any body can help me ?
Alfred.NESWADBA
Please add the dwg-file, we even don't know if you have real intersection points at the locations you are missing a circle.
Also please let us know which version of AutoCAD you are referring to (command _ABOUT and screenshot would be great).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Mesut_Akcan
Please try the following code
Sub test()
ss.SelectOnScreen
    For i = 0 To ss.Count - 1
       If TypeOf ss.Item(i) Is AcadLine Then
              Set line = ss.Item(i)
              line.Update
              For j = i + 1 To ss.Count - 1
                 line1.color = acRed
                 line1.Update
                   fd = True
'                 Else
'                   Exit For
              Next j
    Next i
End Sub
Mesut Akcan - Emekli Teknik Öğretmen
Blog Sayfam -- Youtube Kanalım -- LinkedIn
