How do I get an hourglass mouse pointer to show up?
Hi all,
I want to get the mouse pointer property for a form to change to an
hourglass during a time extensive operation. If I set the property
FormMain.MousePointer = fmMousePointerHourGlass
do a bunch of stuff
FormMain.MousePointer = fmMousePointerDefault
the pointer does not change.
I have tried to force a change by hiding / showing the form but this sets me
off into space and I have to cancel the app to get out. I have also tried
the refresh method for the for but this didn't work either. I am sure there
is some simple way to make this happen but I don't have time to (*&%$&
around for hours to find it. Any help would be appreciated.
Will
Hi Will,
You need to let the system process events and update the screen, by adding
DoEvents. Let's say I had a small form with two command buttons, one that
started a loop, and the other to stop the loop (by setting my boolean test
variable to true), changing the forms mouse pointer would look something
like this:
Option Explicit
Public blnCancel As Boolean
Private Sub UserForm_Initialize()
CommandButton1.Caption = "Start"
CommandButton2.Caption = "Cancel"
End Sub
Private Sub CommandButton1_Click()
'Begin a loop, but first change the
'Pointer
Me.MousePointer = fmMousePointerHourGlass
Do Until blnCancel
'Allow the system to process the queue
DoEvents
'So that things like mouse pointers
'Can be set
Loop
Me.MousePointer = fmMousePointerDefault
End Sub
Private Sub CommandButton2_Click()
blnCancel = True
End Sub
Randall Rath
VB Design
Drop by our message board at
http://www.vbdesign.net/beans/
for help with your VBA questions!
How do I add to your peanuttiness?...I used this in a routine and it works
great, but If I run the same sub twice in a row the hour glass doesn't
appear the second time through the routine. So I added the following
statement (blnCancel = False) to the sub:
blnCancel = False
'Pointer
Do Until blnCancel
DoEvents
'Can be set
Loop
End Sub
Viola, hourglass appears on every "start" click!
Question? How would this routine look if it was implemented as a class?
RLB
"Randall Rath" wrote in message
news:B4A0351246B2B898C2B2F58D3DCBE82F@in.WebX.maYIadrTaRb...
> Hi Will,
> like this:
> Option Explicit
> End Sub
> 'Pointer
> Do Until blnCancel
> DoEvents
> 'Can be set
> Loop
> End Sub
> blnCancel = True
> End Sub
> Randall Rath
> VB Design
