How do I change the plotstamp path
Does anyone know how to change the plotstamp path in a command line or a
profile?
I can change it manually but I have over 150 users and I don't want to walk
to ever station to change this path.
Any help would be appreciated.
Nate
If you know how to use windowsAPI functions, then you will find the plot stamp setting located in the Registry at:
HKEY_CURRENT_USER//SOFTWARE//AUTODESK//AUTOCAD//R15.0//ACAD-12:409//Profiles//ProfileName//Dialogs//Plotstamp.
Look there or simply do a search on the registry for plot.
The value name is PSPFilename, and a string, the value data should be reset to the new path to the plotstamp file, e.g. C:\Program Files\Autodesk Architectural Desktop 3\Support\mm.pss
If you have your office running a standard menu like i have you could simply run this as a lisp function in the acad.lsp file
we do runa standard menu and we are using the
acad.lsp file but I am not very good at lisp.  Can you clue me in on how to
rest the path using the acad.lsp file.  The path I am trying to reset to is
C:\mea-menu\
Thanks again for your help
Nate
If
file
You may want to located the .pss file on your server, so in the future if there is a change, all the users will be updated -- no hassle. As for the first step of getting there, its either working with the registry, or getting a new pair of walking shoes...
>Can you clue me in on how to rest the path using the acad.lsp file
I would suggest confirming first that i have the path correct and have no typos (look at the registry by going to Start->Run->Regedit), but add this to your custom menu .mnl file:
(vl-registry-write
"HKEY_CURRENT_USER\\SOFTWARE\\AUTODESK\\AUTOCAD\\R15.0\\ACAD-12:409\\Profiles\\ProfileName\\Dialogs\\Plotstamp"
"PSPFilename"
"C:\mea-menu\mm.pss"
If your looking to modify this in VBA, have a look at this site: http://w3.one.net/~kevinw/VB/s_modules.htm.
There are quite a number of useful routines listed, including 2 working with the Registry for VB.
Thanks you just saved me a ton of time.  This
worked great.
acad.lsp file
(vl-registry-write
    "PSPFilename"
href="http://w3.one.net/~kevinw/VB/s_modules.htm">http://w3.one.net/~kevinw/VB/s_modules.htm
