How can I delete a block in a block?
I have a block (A1) in a other block (A2) - (A2(A1)) or I have
three or more blocks - (CF(G3(A1))).
The name from the blocks are always different. Only the block A1
have always the same name!
Now I must delete with VBA (AutoCAD 2005) the block A1.
The blocks A2, CF, G3, ... I can also delete, but I don´t know the name!
Dim objBlock As AcadBlock
For i = 0 To ThisDrawing.Blocks.Count - 1
Set objBlock = ThisDrawing.Blocks(i)
If objBlock.Name = "A1" Then obkBlock.Delete '<<< error, because
in the drawing is a blockreference
Next i
Dim objBlockA1 As AcadBlock
Dim objEntity As AcadEntity
Dim objRef As AcadBlockReference
''First verify the block is in the drawing
On Error Resume Next
Set objBlockA1 = ThisDrawing.Blocks("A1")
If Error.Number = 0 Then
On Error GoTo ErrHandler
For Each objBlock In ThisDrawing.Blocks
For Each objEntity in objBlock
If TypeOf objEntity Is AcadBlockReference Then
Set objRef = objEntity
If objRef.Name = "A1" Then objRef.Delete
Next
Next
objBlockA1.Delete
Else
Exit Sub
"Hartmut Callies" wrote in message
news:5450792@discussion.autodesk.com...
Next i
Many thanks!
Hartmut Callies
___________________________________________________________________
"Jeff Mishler" schrieb im Newsbeitrag
news:5450817@discussion.autodesk.com...
Next
Next
objBlockA1.Delete
Else
Exit Sub
Next i
