Highlight drawed entities by layer name
Nicht anwendbar
862Aufrufe
7Antworten
Nachricht 1 von 8
Nicht anwendbar
I have a drawing with two drawingentities.
a circle drawed in the layer named "layer01" and
a line drawed in the layer named "layer02"
Now I want a vba code that select (highlight) all drawed entities in layer01 and layer02.
That's all
Is that possible in VBA?
gr. Laszlo
0 „Gefällt mir“-Angaben
Akzeptierte Lösungen (1)
863Aufrufe
7Antworten
Antworten (7)
Nachricht 2 von 8
Alfred.NESWADBA
Public Sub HighlightTest()
   Dim tSelSet As AcadSelectionSet
   Set tSelSet = getSelSetByLayer("Layer01")
   If tSelSet Is Nothing Then
      MsgBox ("No Selectionset")
   ElseIf tSelSet.Count = 0 Then
      MsgBox ("No objects found on Layer 'Layer01'")
   Else
      Dim tEnt As AcadEntity
      For Each tEnt In tSelSet
         tEnt.Highlight (True)
      Next
End Sub
Private Function getSelSetByLayer(ByVal LayerName As String) As AcadSelectionSet
   Dim tRetVal As AcadSelectionSet
   On Error Resume Next
   'create selectionset
   Set tRetVal = ThisDrawing.SelectionSets.Add("mySelSet")
   If tRetVal Is Nothing Then Set tRetVal = ThisDrawing.SelectionSets.Item("mySelSet")
   'create filter for selection
   Dim tDxfCodes(0) As Integer: tDxfCodes(0) = 8     '8=dxfcode for "layername"
   Dim tDxfValues(0) As Variant: tDxfValues(0) = LayerName
   'select
   tRetVal.Clear
   Call tRetVal.Select(acSelectionSetAll, , , tDxfCodes, tDxfValues)
   'return
   Set getSelSetByLayer = tRetVal
End Function
HTH, - alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Nachricht 3 von 8
Nicht anwendbar
Thank you Alfred, but it only works with layer01 not with layer02. Smiley (traurig)
I tried: Set tSelSet = getSelSetByLayer("Layer01", "layer02") but it returned with an error:
"Wrong number of arguments or invalid property assignement."
I forgot something?
gr. László
Nachricht 4 von 8
Alfred.NESWADBA
you can define the layername-filter in one of the following modes:
  • using a comma as separator to define multiple distinct layernames (be careful, don't write a space after the comma)
  • using wildchars like "?" or "*"
HTH, - alfred -
Samples:
Set tSelSet = getSelSetByLayer("Layer01,Layer02")
Set tSelSet = getSelSetByLayer("Layer0?")
Set tSelSet = getSelSetByLayer("Layer??")
Set tSelSet = getSelSetByLayer("Layer*")
Alfred NESWADBA
Nachricht 5 von 8
Nicht anwendbar
Thank you again Alfred!
It works great.
I learned a lot from it.
gr. LaszloSmiley (überglücklich)
Nachricht 6 von 8
Nicht anwendbar
This code works fine.
Now I wants a different layer zb. layer03 to be highlight (false). How to combine this in the same code?
gr. Laszlo
   Else
      Next
End Sub
   'select
   tRetVal.Clear
   'return
End Function
Nachricht 7 von 8
Alfred.NESWADBA
   Set tSelSet = getSelSetByLayer("Layer01,Layer02,Layer03")
      MsgBox ("No objects found on Layer 'Layer01/02/02'")
   Else
         Select case ucase(tEnt.Layer)
            case "LAYER01","LAYER02"
            case "LAYER03"
               tEnt.Highlight (false)
         End Select
      Next
End Sub
- alfred -
Alfred NESWADBA
Nachricht 8 von 8
Nicht anwendbar
Akzeptierte Lösung
It's simplier than I thought.
Thanks!
gr. Laszlo
