Help with util.InitializeUserInput use
Nicht anwendbar
370Aufrufe
4Antworten
Nachricht 1 von 5
Nicht anwendbar
I am trying to use keywords in response to a getpoint function. For some
reason, VBA goes into an unhandled error. What am I doing wrong? I need
to pick a point or simply ENTER or type Open, Close, Fir Spline Xit in
response to getpoint.
See attached code below. Any pointers are greatly appreciated.
Regards
Rakesh
On Error Resume Next
kwdLst = "Open Close Fit Spline Xit"
util.InitializeUserInput 128, kwdLst
pt1 = util.GetPoint(, vbCrLf + "Pick first point:")
If Err Then
If StrComp(Err.Description, "User input is a keyword", 1) = 0 Then
' One of the keywords was entered
kwd = util.GetInput
util.Prompt "Keyword entered was: " + kwd
Else
util.Prompt "Error in point selection" + Err.Description
Err.Clear
Err.Clear
AutoCAD customization for Engineering/Mapping/GIS
Get GeoTools @ http://www.4d-technologies.com/geotools
Build MyGeoTools @
http://www.4d-technologies.com/geotools/my_geotools.htm
FREE downloads : http://www.4d-technologies.com/techcenter
0 „Gefällt mir“-Angaben
371Aufrufe
4Antworten
Antworten (4)
Nachricht 2 von 5
Nicht anwendbar
Hi there,
I could be wrong but I thought you needed to check what was in the Err
object rather than just assuming the object was there.
For example:
If Err.Number <> 0 Then
[Do something]
By doing this as your first conditional test you can eliminate your nested
If-Then which checks for the Error description. Checking for an error
number is far easier than checking the error description.
Also note that the Err properties are automatically set ot zero or "" when
any form of the Resume statement is used. Even though the Clear method is
valid and useful there is no need to use it as you have done.
Hope that helps a little or even a lot.
Jason
Rakesh Rao wrote in message
news:3D5F5380.9A0F5138@vsnl.net...
> Hello,
> Regards
> Rakesh
> If Err Then
> kwd = util.GetInput
> Else
> Err.Clear
> End If
> Err.Clear
> End If
> Build MyGeoTools @
Nachricht 3 von 5
Nicht anwendbar
How can you get an error when you are using On Error Resume Next? The code
you posted below cannot be causing it directly, are you sure it is not
coming from another procedure that runs after what you have posted below?
Jacob Dinardi
"Rakesh Rao" wrote in message
> Hello,
> Regards
> Rakesh
> If Err Then
> kwd = util.GetInput
> Else
> Err.Clear
> End If
> Err.Clear
> End If
> Build MyGeoTools @
Nachricht 4 von 5
Nicht anwendbar
Hi Jacob,
Thanks for your response.
Here is my full code:
I am unable to trap the keywords entered. Do you have a working example of how
to do it?
Sub Main()
Dim util As AcadUtility
Dim pickedPt, pt1, pt2 As Variant
Dim objName As AcadEntity
Dim ang As Double
Dim kwd, kwdLst As String
Set glAcad = GetObject(, "AutoCAD.Application")
Set util = glAcad.ActiveDocument.Utility
util.Prompt vbCrLf + "Demonstrates use of utility objects for user
interaction."
Err.Clear
ThisDrawing.Utility.InitializeUserInput 128, kwdLst
pt1 = util.GetPoint(, "Pick first point:")
If Err.Description = "User input is a keyword" Then
kwd = util.GetInput
Else
Err.Clear
Err.Clear
End Sub
> Regards,
> Jacob Dinardi
> > Hello,
> > Regards
> > Rakesh
> > If Err Then
> > kwd = util.GetInput
> > Else
> > Err.Clear
> > End If
> > Err.Clear
> > End If
> > Build MyGeoTools @
Build MyGeoTools @ http://www.4d-technologies.com/geotools/my_geotools.htm
Nachricht 5 von 5
Nicht anwendbar
It looks like an external application not a VBA macro. In that case the
instruction
only works if AutoCad is runnig. If Autocad is closed it generates an
unhandled error (as you referred).
The solution is well documented, you must begin in that way
' Proceso de conexión con AutoCAD
Set aCAD = GetObject(, "AutoCAD.Application")
If Err Then
Err.Clear
Set aCAD = CreateObject("AutoCAD.Application")
If Err Then
*** ERROR ***
