help with my ADT 'Generate Layers from Layer Key' Code?
The section: 're-set layer key overrides
below produces the error:
Run-time error '-214746259 (80004005)'
Method 'Value' of Object 'IAecLayerOverrideSettings' failed
See VBA code below:
Sub GenerateLayersFromLayerKey()
getAecArchBaseApp
getAecArchDbPref
Dim CurrentLayerKeyStyle As String
CurrentLayerKeyStyle = getLayerStandard
Dim AecDoc As New AecArchBaseDocument
AecDoc.Init ThisDrawing
Dim LayKeyStyle As AecLayerKeyStyle
Set LayKeyStyle = AecDoc.LayerKeyStyles(CurrentLayerKeyStyle)
'save current Layer Key Overrides
Dim SavedOverrideSettings() As Variant
With LayKeyStyle.OverrideSettings
SavedOverrideSettings = Array((Array(.Item("Discipline").Name,
.Item("Discipline").Value)), _
(Array(.Item("Status").Name,
.Item("Status").Value)), _
(Array(.Item("Component").Name,
.Item("Component").Value)), _
(Array(.Item("Description").Name,
.Item("Description").Value)) _
End With
'set Layer Standard Wildcards
.Item("Discipline").Value = "?"
.Item("Status").Value = "-?"
.Item("Component").Value = "-????"
.Item("Description").Value = "-*"
End With
ThisDrawing.SendCommand ("LayerKeyOverride ")
'build Layer Generate Filter String
Dim LayerFilter As String
'Discipline Field is required
If .Item("Discipline").Value <> "" Then
LayerFilter = .Item("Discipline").Value
Else
LayerFilter = LayerFilter & "?"
'Status Field is optional
If .Item("Status").Value <> "" Then
LayerFilter = LayerFilter & .Item("Status").Value
Else
LayerFilter = LayerFilter & "*"
'Component Field is required
If .Item("Component").Value <> "" Then
LayerFilter = LayerFilter & .Item("Component").Value
Else
LayerFilter = LayerFilter & "-????"
'Description Field is optional
If .Item("Description").Value <> "" Then
LayerFilter = LayerFilter & .Item("Description").Value
Else
End With
For Each x In SavedOverrideSettings
LayKeyStyle.OverrideSettings.Item(x(1)).Value = x(2)
Next x
Dim LayerKey As AecLayerKey
For Each LayerKey In LayKeyStyle.Keys
If LayerKey.Index = 86 Then 'special code for the 'Count' item, I think?
GoTo SkipLayerKey
If LayerKey.Layer Like LayerFilter Then
LayKeyStyle.GenerateLayer (LayerKey.Name)
SkipLayerKey:
Next LayerKey
EndSub:
End Sub
Ok,
problem solved.
Credit to B.Winterscheidt over in the arch-desktop discussion group.
The line above was the culprit,
with regard to its position in sequence of things.
Wasn't really behaving 'synchronously', as advertised,...
>Next x
...which caused the code above to error.
Moving this piece of code 'further downstream' to execute just before the
End Sub,
did the trick.
I have *no idea* why...
(but I'll take it!)
> End Sub
Who advertised it as being synchronous? We usually go out of our way to tell
everyone to stay away from SendCommand if possible, because it is
asyncronous.
Ed
> to tell everyone to stay away from SendCommand if possible, because
> it is asyncronous.
snipped from the Help file.
"This method is generally synchronous. However, if the command sent with
this method requires any user interaction (such as picking a point on the
screen) then this method will continue as soon as the user input begins. The
command will then continue to be processed asynchronously."
I guess my use of the Layer Key Overrides UI,
constitutes 'user interaction', eh?
I should read these things more closely...
Oh, the "help" file. That blurb is a little misleading,
easily misunderstood. Although SendCommand method is processed syncronously,
the processing of whatever is output to the command line is asyncronous.
Ed
