Help with Multiple Regions in an Array var
I am selecting a Peeline 🙂 one by one & converting them to regions. I would like to know if it’s possible to store these regions as I create them in an array var so that I could later do a Boolen acUnion on them. Please provide an example if possible. Thanks in advance.
William
You can use a Collection or Dictionary which are dynamic in size (size increased as needed), to store your regions.
When your done use something like the follwoing to fill
your array. Notice a collection is base 1 and the array is
base 0 by default.
ReDim plineArr(coll.Count - 1)
For i = 0 To coll.Count - 1
Set plineArr(i) = coll(i + 1)
Next i
Ok, I have provided part of the code. I have tried almost everything but I still can't get it to work. I have pasted the code @ the location where I think it needs to be without editing it. Please show me how u declared the PlineArr and feel free to edit my code the correct way. Thanks.
William
ThisDrawing.Utility.GetEntity oEnt, vPick, "Select pline to create region "
If TypeOf oEnt Is AcadLWPolyline Then
Set oRegObjects(0) = oEnt
Set PlineArr = oEnt
oRegions = ThisDrawing.ModelSpace.AddRegion(oRegObjects)
ReDim PlineArr(coll.Count - 1)
Set PlineArr(i) = coll(i + 1)
Next i
Else
MsgBox "You must select a Polyline", vbSystemModal
all that in a few hours... It usually takes me a few days..:<)
see if this gives you some ideas. I've used a selection
set with a filter for closed plines. You will need some
error handling.
[code]
Option Explicit
Sub PlinesToRegion()
Dim SS As AcadSelectionSet
Dim filType(1) As Integer
Dim filData(1)
'filter data for closed lwpolys
filType(0) = 0
filData(0) = "LWPOLYLINE"
filType(1) = 70
filData(1) = 1
Set SS = SSAdd("test")
SS.SelectOnScreen filType, filData
Dim objectArray(0) As AcadEntity
Dim regionEnt
Dim i As Integer
For i = 0 To SS.Count - 1
Set objectArray(0) = SS(i)
regionEnt = ThisDrawing.ModelSpace.AddRegion _
(objectArray)
Next i
Call SSRemove("test")
End Sub
Function SSAdd(inName As String) As AcadSelectionSet
On Error Resume Next
With ThisDrawing
.SelectionSets(inName).Delete
Set SSAdd = .SelectionSets.Add(inName)
End With
End Function
Sub SSRemove(inName As String)
ThisDrawing.SelectionSets(inName).Delete
End Sub
[/code]
