help with IntersectWith, doesnt always return lowest point first.
Message 1 of 8
AutoCad2002
Win2000
How can I get the Intersect with to return the array with the lowest
selected points first,
example:
I have a rectangle and a vertical line drawn through it, depending on how I
draw that rectangle sometime the returned points are first the Upper
intersection,Lower intersection and sometimes they are Lower intersection,
Upper intersection - the latter is what I am aiming for. I need to insert
some blocks from the lower point to the higher point, the way I have it now
is to sporadic.
Without pasting to much useless, this is the intersection part:
If Me.optVertical.value = True Then
intPoints = objOutlineItem.IntersectWith(EachPLine, acExtendNone)
insertionPntOne(0) = intPoints(0)
insertionPntOne(1) = intPoints(1)
insertionPntOne(2) = intPoints(2)
insertionPntTwo(0) = intPoints(3)
insertionPntTwo(1) = intPoints(4)
insertionPntTwo(2) = intPoints(5)
Set blockRefObjLE = ThisDrawing.ModelSpace.InsertBlock(insertionPntTwo,
blkSstrand, 1#, 1#, 1#, 1.5708)
Set blockRefObjAN = ThisDrawing.ModelSpace.InsertBlock(insertionPntOne,
blkSanchor, 1#, 1#, 1#, 1.5708)
AnyHelp, thanks
Replies (7)
Message 2 of 8
Here I even found what I was talking about by
searching the web on an OLD acadx webpage:
This method is especially useful with coordinate
arrays returned by the IntersectWith method of AcadEntity (which does not return
intersection points in any particular order). Hence, this method can be used to
rearrange the order of a set of points on a curve where it is intersected by
another object, so that the intersection points are in their natural order of
traversal.
But thats for dealing with curves!
Message 3 of 8
Hi Jose,
Try using the insersectwith method of the acadline, then check the line's
angle property to determine if the points need to be reversed. Also be
cautious with the acextend options so that you don't accidentally grab
additional points. If that doesn't work for you, you will have to write
code that sorts the points by comparing the x and y elements.
-Josh
Jose Guia wrote:
> AutoCad2002
> Win2000
> example:
> is to sporadic.
> End If
> AnyHelp, thanks
Message 4 of 8
Josh,
*I have the noextend option so there is no accidental point grabbing,
*the acadline doesn't help I use acadentity because of my GetEntity
I think your right about the following:
Any ideas on how to do this ?
thanks,
joseguia
"Minkwitz Design" wrote in message
news:[email protected]...
> Hi Jose,
> -Josh
> Jose Guia wrote:
> > AutoCad2002
> > Win2000
> > example:
how I
intersection,
insert
now
> > is to sporadic.
> > Set blockRefObjLE =
> > Set blockRefObjAN =
> > End If
> > AnyHelp, thanks
Message 5 of 8
The quote below relates to SortCurvePoints, which is a
method of the AcadXCurve class from AcadX.arx, and it
will sort the points on the curve based on their distance
from the start, but keep in mind that because it always
sorts the coordinates from the start of the curve (or in
the case of a LINE, from the StarPoint), if the line is
reversed, then you have the same problem all over again.
"Jose Guia" wrote in message
> Here I even found what I was talking about by searching the web on an OLD
acadx webpage:
> This method is especially useful with coordinate arrays returned by the
IntersectWith method of AcadEntity (which does not return intersection
points in any particular order). Hence, this method can be used to rearrange
the order of a set of points on a curve where it is intersected by another
traversal.
> http://members.bellatlantic.net/~vze2vjds/acadx/AcadX.htm
Message 6 of 8
If the line will always be vertical or you always want to go from the
lowest point in the Y to the higher point,,,, where retval is the array
of points returned from intersectwith:
dim Lpt (0 to 2) as double, Upt (0 to 2) as double
if retval(1)>retval(4) then
Lpt(0)=retval(3):Lpt(1)=retval(4):Lpt(2)=0#'or retval(5)
Upt(0)=retval(0):Upt(1)=retval(1):Upt(2)=0#'or retval(2)
else
Lpt(0)=retval(0):Lpt(1)=retval(1):Lpt(2)=0#'or retval(2)
Upt(0)=retval(3):Upt(1)=retval(4):Upt(2)=0#'or retval(5)
end if
Jose Guia wrote:
> Josh,
> thanks,
> joseguia
>>Hi Jose,
>>-Josh
>>Jose Guia wrote:
>>>AutoCad2002
>>>Win2000
>>>example:
> how I
> intersection,
> insert
> now
>>>is to sporadic.
>>> Set blockRefObjLE =
>>> Set blockRefObjAN =
>>>End If
>>>AnyHelp, thanks
Message 7 of 8
I see, kinda makes me wonder why I didn't think of that.
I'll try later today and re-post.
thanks for your help!
joseguia
> else
> end if
> Jose Guia wrote:
> > Josh,
> > thanks,
> > joseguia
> >>Hi Jose,
line's
> >>-Josh
> >>Jose Guia wrote:
> >>>AutoCad2002
> >>>Win2000
> >>>example:
> > how I
> > intersection,
> > insert
> > now
> >>>is to sporadic.
> >>> Set blockRefObjLE =
> >>> Set blockRefObjAN =
> >>>End If
> >>>AnyHelp, thanks
Message 8 of 8
Worked like a champ!
thanks,
joseguia
> joseguia
> > else
> > end if
> > Jose Guia wrote:
> > > Josh,
> > > thanks,
> > > joseguia
> > >>Hi Jose,
> line's
write
> > >>-Josh
> > >>Jose Guia wrote:
> > >>>AutoCad2002
> > >>>Win2000
> > >>>example:
on
> > > how I
> > > intersection,
> > > insert
it
> > > now
> > >>>is to sporadic.
> > >>> Set blockRefObjLE =
> > >>> Set blockRefObjAN =
> > >>>End If
> > >>>AnyHelp, thanks
