Help, Selection set filter
Hello, I am trying to create a filtered selection set to capture
the block name(handle), unique id, and insertion points (x,y,z).
Attached code comes back empty.
Help.
tpefilterstr = "name1,name2,name3,name4"
Dim tpearrayA(0 To 2) As Integer
Dim tpearrayB(0 To 2) As Variant
Dim tpefiltera As Variant
Dim tpefilterb As Variant
Dim tpefilterstr As String
For cntcb = 0 To 12
nulval = IsNull(tpecbarry(cntcb))
If (tpecbarry(cntcb) <> "" And nulval = False) Then
tpefilterstr = tpefilterstr & tpecbarry(cntcb) & ","
Next
tpearrayA(0) = 2:
tpearrayB(0) = tpefilterstr
tpearrayA(1) = 5:
tpearrayA(2) = 10:
tpefiltera = tpearrayA
tpefilterb = tpearrayB
ThisDrawing.SelectionSets.Item("tpefilteredset").Select acSelectionSetAll, , , tpefiltera, tpefilterb
I changed the code to include an array for the code "10" coord.(x,y,z,) data. No change.
Please HELP.
Dim tpeInsPt(0 To 2) As Double
For cntcb = 0 To 12
Next
tpearrayA(0) = 2:
tpearrayA(1) = 5:
tpearrayB(1) = "*"
tpearrayA(2) = 10:
tpearrayB(2) = tpeInsPt
dragnsbld
You could just add this to your code:
change the strName to your block name, when it is ran you can get all the data you are looking for by using a For..Next and have it returned however you chose.
Dim intCode() As Integer, varCodeValue() As Variant
Set ss = CreateSelectionSet
ReDim intCode(0)
ReDim varCodeValue(0)
intCode(0) = 2
varCodeValue(0) = strName
Public Function CreateSelectionSet(Optional ssName As String = "SelSt") As AcadSelectionSet
Dim ss As AcadSelectionSet
On Error Resume Next
Set ss = ThisDrawing.SelectionSets(ssName)
If Err Then Set ss = ThisDrawing.SelectionSets.Add(ssName)
ss.Clear
Set CreateSelectionSet = ss
End Function
Thank you
What format/layout will the selection set be in?
will it have column names/numbers?
When I do a: for each "2." or "handle name" in "handle" <--?
How do I address the coord (x,y,z) and the "unique id" data?
dragnsbld
Here is a sample, you choose the format order.
I used this before to create a DB from a drawings Blks and vice versa. all the information is there and if you need to you can add a Dim for OBJ1 as acadBlock or text or line whatever and use the set OBJ1 = Obj and get other info.
dim Obj as acadentity
for each Obj in ss
obj.handle
obj.insertionpoint
next Message was edited by: Dragnsbld
Thank you thank you thank you!!!!!!
