Help needed...CommonDlg method
Message 1 of 10
Hi All,
Can neone please help me with this. I am getting a type mismatch error at If .ShowOpen Then . If I give Me.cdlgMainFrm.ShowOpen as a separate line instead of giving in if ,I am getting an error that ParseFileNames method does not exist. Is ParseFileNames method a inbuilt method. Ne help with this is appreciated.
Private Sub CommandButton1_Click()
Me.cdlgMainFrm.DialogTitle = "Select Drawing files"
With cdlgMainFrm
.Filter = "AutoCAD Drawings (*.dwg)|*.dwg"
.Flags = OFN_ALLOWMULTISELECT Or OFN_EXPLORER
.MaxFileSize = 3072
If .ShowOpen Then
Files = Me.cdlgMainFrm.ParseFileNames 'I am copying the files in ParseFileNames into Files which is a Variant.
End With
End Sub
Avantika.
Replies (9)
Message 2 of 10
Dim success as Long
success = .ShowOpen
If success > 0 Then Files = .ParseFileNames
R. Robert Bell
wrote in message news:5208012@discussion.autodesk.com...
Hi All,
is appreciated.
With cdlgMainFrm
.MaxFileSize = 3072
If .ShowOpen Then
End With
End Sub
Avantika.
Message 3 of 10
Thanks Robert...But that did not help.....I am still getting that error.....
Do we need to add any headers ??? Is ParseFileNames a method provided by CommonDialogBox??? Please someone help me figure this out....
Message 4 of 10
That method exists in the class module I use (attached).
R. Robert Bell
wrote in message news:5209184@discussion.autodesk.com...
Message 5 of 10
hi Robert ,
I have both AutoCAD 2006 and 2007 full licensed version but i am not able to use common control tool, when i pick and drag common control on the user form i am getting an error msg "The Control Could not be created because it is not properly licensed. do you have a solution.
Message 6 of 10
Do a search as this has been covered many times in this NG..
G'Luck
Bob Coward
Message 7 of 10
pge 395 of joe sutphins 2006 vba book illustrats how ths is done using
windws api.
wrote in message news:5216483@discussion.autodesk.com...
hi Robert ,
Message 8 of 10
I must have forgotten to attach the class I mentioned in the earlier post.
BTW, you cannot use VB controls in VBA projects.
R. Robert Bell
hi Robert ,
Message 9 of 10
Hi
But i have another project downloaded from this website where i can directly pick common dialog from toolbar and place it on user form ,but this is not posiible for any other project ,the downloaded project does not has any class or module and has no special code for common dialog placing.
Do you have solution for this.
Benny
Message 10 of 10
You cannot use the VB control in a VBA project. That is why CommonDialog
classes are created for VBA. That provides the functionality of the VB
control when you are not permitted to use the control.
All you need to to to use the class is to add a reference to the class'
project file, and then use code similar to this:
Sub Test()
Dim myOpen As CommonDialogProject.CommonDialog
Set myOpen = CommonDialogProject.Init
myOpen.DialogTitle = "Select drawings"
myOpen.Filter = "Drawings (*.dwg)|*.dwg"
myOpen.Flags = OFN_ALLOWMULTISELECT + _
OFN_EXPLORER + _
OFN_FILEMUSTEXIST + _
OFN_HIDEREADONLY + _
OFN_PATHMUSTEXIST
myOpen.InitDir = "C:\datasets\CP21-2"
myOpen.MaxFileSize = 2048
Dim success As Long
success = myOpen.ShowOpen
Dim myFiles as Variant
If success > 0 Then myFiles = myOpen.ParseFileNames
End Sub
R. Robert Bell
wrote in message news:5217709@discussion.autodesk.com...
Hi
Benny
