Help about set text in Autocad VBA
With this sub, I create a text in AutoCAD.
Sub Ch4_ChangeTextHeight()
Dim textObj As AcadText
Dim textString As String
Dim insertionPoint(0 To 2) As Double
Dim height As Double
textString = "Hello, World."
insertionPoint(0) = 0
insertionPoint(1) = 0
insertionPoint(2) = 0
height = 1
Set textObj = ThisDrawing.ModelSpace. _
AddText(textString, insertionPoint, height)
End Sub
But, when I type -vp  and then "1,1,1" to set view in AutoCAD, my view will change, and I can not see my text as before.
Tell me how to set View for this text or something similar 😞
Alfred.NESWADBA
Sorry, we (at lest I) need some details
that's normal, that the viewchanges with command _VPOINT ... did you estimate anything else then a 3D-rotated view now? If so, what should the display look like?
>> [...] and I can not see my text as before
Well, you see the text now from a different angle in XY and from a different elevation. I see not any difference to a text that is created with TEXT-command (without VBA) and that produced by your code.
Or what is it that makes you thinking that something went wrong? Explain it, maybe screenshots can help or drawings (one what happend and another DWG what you estimate instead).
If you are wondering that the text-object is not vertical oriented after you changed your viewpoint then .... that is normal. A text-object "lays" in the XY-plane of the UCS that was active during creation of the text.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
thank you for so quick reply
sorry for my description
then I change my view
And how I can change the view of this text or st similar  as below
Alfred.NESWADBA
if you take a paper with some characters on it and place it on the floor. Then first look to the text from vertical above the paper, next go a few steps away and look then to the characters ... did they follow you? NO 😉
And that's the same like any geometry in AutoCAD does, if you place a quader in your scene and you change then your point of view, nothing follows with you, but you see the quader-object from another side and another height. A text-object is nothing else than a simple geometry object, it stays where you placed it as long as you don't modify the geometry.
To your screen 3, this is just temporary for editing the text-content. So during modification AutoCAD transforms the text-content parallel to screenview and when you finished the modification the temporary display is off, the text is back to it's creation plane.
But at least, there is no difference between a text created manually with AutoCAD-commands or with VBA.
- alfred -
Alfred NESWADBA
Hallex
Set ISO View you  need , draw some text, then
you can play around this quick demo:
    Public Sub SetTextPlanar()
    Dim oText As AcadText
    Dim pickPt As Variant
    Dim oEnt As AcadEntity
    Dim textPt As Variant
    Dim vdir As Variant
    Dim align As Integer
    Dim txtAlign As Variant
    vdir = ThisDrawing.GetVariable("viewdir")
    ThisDrawing.Utility.GetEntity oEnt, pickPt, vbCr & "Select text: "
    If TypeOf oEnt Is AcadText Then
    Set oText = oEnt
    textPt = oText.InsertionPoint
    align = oText.Alignment
    txtAlign = oText.TextAlignmentPoint
    oText.Normal = vdir
    If align = 0 Then
    oText.InsertionPoint = textPt
    ElseIf align = 5 Or align = 3 Then
    oText.Alignment = align
    oText.TextAlignmentPoint = txtAlign
    Else
    ThisDrawing.Regen acActiveViewport
End Sub
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
