having problem with getinterfaceobject
10:31 AM
The following function always fails at the last line.
GetobjProj = objProj
The error msg says:
object variable or with block variable not set.
Can someone help? Thanks a lot.
Public Function GetobjProj(ProjID As String) As Object
Dim ProjID2 As String
ProjID2 = ProjID & "." & Left(ThisDrawing.GetVariable("ACADVER"), 2)
Dim objProj As Object
With ThisDrawing.Application
Set objProj = .GetInterfaceObject(ProjID2)
If objProj Is Nothing Then
Set objProj = .GetInterfaceObject(ProjID)
End With
End Function
The error msg says:
End With
End Function
