hatch pattern
hatch pattern
jostroopers
hatch pattern
jostroopers
Is it possible to influence through vba or dotnet hatch pattern
I mean to say the numbers that you see when you open a .Pat with notepad  to change via a form in vba or dotnet so that you can influence the pattern without applying a different pattern.
Mvg Jos
Youre drawings are as good as the symbols that compleet them.....
truss_85
Yes it is possible with both .net and vba here is a quick example of vba.
Sub WriteTextFile()
Dim fs As Object, tf As Object
Set fs = CreateObject("Scripting.FileSystemObject")
Set tf = fs.CreateTextFile("C:\*****.pat", True)
tf.WriteLine "test for 1.line"
tf.WriteLine "test for 2.line"
tf.Close
End Sub
