Hatch - moving in model space
OceanaPolynom
OceanaPolynom
Hello
I wrote a program that trys to move all the entities in a dwg file by calculating a grid transformation for each point in each entity. For example to move a pline
Code:   Case Is = "AcDb2dPolyline"
                Set o2DP = oEnt
                retCoord = o2DP.Coordinates
                For j% = 0 To UBound(retCoord) Step 3
                     yaa# = retCoord(j%)
                     xaa# = retCoord(j% + 1)
                     Call UTMCartGeo(yaa#, xaa#, latutm#, longutm#)
                     h# = Val(TextBoxH.Text)
                     Call UTMGEOtoITMGEO(latutm#, longutm#, h#, pp#, ll#)
                     Call ITMGeotoITMCart(pp#, ll#, e#, n#)
                     retCoord(j%) = e#
                     retCoord(j% + 1) = n#
                 Next j%
                 o2DP.Coordinates = retCoord
My problem is moving hatch entities. I haven't succeeded in finding equivalent code to move the hatch entities. I did find another post here, but I still don't get it.
Thank you
John
Alfred.NESWADBA
just as a tip: if the hatches are set to assiciative ==> don't they update themselves after modifying there border-geomtries?
And for your prog: you have
  • Sub GetLoopAt(Index As Long, ObjectArray)
  • Sub InsertLoopAt(Index As Long, LoopType As AcLoopType, ObjectArray)
  • Property NumberOfLoops As Long
have you tried to play with these?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
OceanaPolynom
Hello
Thanks for replying.   Although the hatches are associative, only the boundary is moved, not the hatch.  GetLoopAt
returns the objects that are bounding the hatched area.  These objects are moved anyway by their respective Case IS=
sections of code.  So I'm still stuck.
Thank you
John
Alfred.NESWADBA
what if you do a Hatch.Update after you moved the boundary-geomtries?
I have not enough time at the moment, so I can't spent time to do some testing now ... what if you just do your modifications to all geometry but not the hatches? Either then a Hatch.Update .... or in the drawing a REGEN?
If you don't update the hatches ... have they lost the associativity?
- alfred -
Alfred NESWADBA
OceanaPolynom
Hello
I will start to check your suggestions now.
Thanks again
John
OceanaPolynom
Hello
Thanks to your helpfull suggestions I have solved (partly) my problem.  After first transforming all entities except hatches to their new grid location, the program recreates the hatch objects at the new locations, except in cases where the boundary entities hve been erased.  here is the hatch code:
'all entities except hatches have been transformed to their new locations by here
Dim fcode(0) As Integer
Dim fvalue(0) As Variant
fcode(0) = 0
fvalue(0) = "Hatch"
Dim groupCode As Variant, dataCode As Variant
groupCode = fcode
dataCode = fvalue
Dim ssetall As AcadSelectionSet
On Error Resume Next
A2K.ActiveDocument.SelectionSets.Item("sset").Delete
On Error GoTo 0
Set ssetall = A2K.ActiveDocument.SelectionSets.Add("sset")
'select all hatch objects
ssetall.Select acSelectionSetAll, , , groupCode, dataCode
For i = 0 To ssetall.Count - 1
      Set oEnt = ssetall.Item(i)
      Set oHatch = oEnt
      ' Find the objects that make up the first (outer) loop
      Dim loopType As Variant
      Dim loopObjs As Variant
      Dim outerLoop(0 To 0) As AcadEntity
      Dim innerLoop(0 To 0) As AcadEntity
      oHatch.GetLoopAt 0, loopObjs
      ' Find the types of the objects in the loop
      Dim Ii As Integer
      Dim objName As String
      For Ii = LBound(loopObjs) To UBound(loopObjs)
          Set outerLoop(Ii) = loopObjs(Ii)
      Next Ii
      jk% = oHatch.NumberOfLoops
      oHatch.AppendOuterLoop (outerLoop)
      ' Find the objects that make up the each inner loop
      For lc% = 1 To jk% - 1
          oHatch.GetLoopAt lc%, loopObjs
              Set innerLoop(Ii) = loopObjs(Ii)
          Next Ii
          oHatch.AppendInnerLoop (innerLoop)
      Next lc%
  oHatch.Evaluate
      oHatch.Update
Next i
 Attached are 2 dwg files.  Hatch6.dwg is the source file.  Hatch6UTM36N.dwg is the file created by the code.  Zoom extents on the results file reveals that while the hatches are restored at the new locations, the original hatch objects remain in place.  The hatch without the boundary object, does not move and will cause an error if not trapped.  Associativity is maintained at the new hatch locations.
Thank you
John
Alfred.NESWADBA
in that case you just could move the hatch, can't you? If the borders don't exist any more the hatch could not be associative any more (and so also does not have to be after your repositioning)
Or do you do any non-linear disortion?
- alfred -
Alfred NESWADBA
