Gracefully Handling Multiple Users Accessing the Same File Simultaneously
05:25 AM
I found out the hard way that when many users are trying
to do run an OpenTextFile statement on the same file at
the same time then some users will get the
"Permission Denied" error.
In order to solve the problem what I did was write a function
like the one below which tries to test if a file is currently
being open and being read or written to by another person.
I have put line numbers here just for ease in referring to
portions of the program.
10 Function IsReadyToOpen(strFileName As String) As Boolean
20 Dim blnIsReady As Boolean, fle As New FileSystemObject
30 Dim tst As TextStream
40 On Error GoTo errHand
50 blnIsReady = True
60 Set tst = fle.OpenTextFile(strFileName, ForReading, False)
70 tst.Close
80 Set tst = Nothing
90 Set fle = Nothing
'''no permission denial everything went as expected
100 IsReadyToOpen = blnIsReady
110 Exit Function
120 errHand:
'''permission is being denied
130 blnIsReady = False
140 IsReadyToOpen = blnIsReady
150 Set fle = Nothing
160 End Function
I am concerned that I might inadvertently corrupt
file or lose data due to this function and want it to be as
programming tight as possible.
You will notice this as the heart of the routine that if the
function issues the OpenTextfile and it fails then it will set the
return value to false in line 130-140 then just set fle to nothing
I am not so comfortable with not closing a file before setting
fle to nothing. But the problem I have is what will happen if I
try to issue a tst.close in a line say 145. I am not too sure how
that will work... first an error in opening has made the execution
jump to this point and if the said tst.close in 145 causes yet
another execution error already from within the error handle then
will that leave me in a crash on top of data loss or file corruption?
In other words how do I execute this thing as gracefully as possible
making sure that files are properly closed and fle set to nothing?
I would be open to any ideas in case anybody knows of any technique
that will allow me to know if a file is already open without actually
issuing an OpenTextFile method ... such a technique would be safer
I think.
Thanks you so much for all the kind help you can give.
Matt
70 tst.Close
110 Exit Function
120 errHand:
160 End Function
I think.
Matt
