Please pardon the shout but
NO NO NO
DO NOT EVER USE THE GOTO UNLESS YOU ARE ERROR
HANDLING.
off the soapbox
ie
sub test()
on error goto test_error
dim iTest as
integer
iTest = "a"
exit sub
test_error:
msgbox "Error occured.",
vbCritical
end sub
or
sub test()
on error resume next
dim vPt as Variant
RETRY:
vPt = thisdrawing.getpoint (, "Pick point: ")
if isempty(vpt)=true then goto RETRY
end sub
The second example is still a error handler because in the AC world, if a
user right clicks (or presses enter) that would be a error. This would catch the
'error' condition and not allow the user to exit without making a pick. I do not
think that VB still supports line numbers fully. The better way to go is to use
a label, as in the first example. Along the opening line, if you goto someplace
out of the sub (which you may not be able to) that is the worst programming
practice possible. If you need to go outside the sub, with a expected return,
just use another sub, or a function. In the first example, after the message
box, you could resume next, this would return your code to the next line after
the error jump. Be forewarned notice the exit sub before the test_error, if you
do not do this, the code in test_error *WILL* be executed. Maybe good, maybe
bad. Unfortunately, this is also the only way to handle errors in vb until
you(we) move to .net.
HTH, and that I was not too harsh.
Chris
How
do I use the GoTo command When I do it I am told that the line numer is not
yet defined but I can not figure out how to define the line
number.
