Getting the insertion point of a text item
Hi all!
I am trying to write some code to do the following:
This is the order they will happen as well!
1. Allow the user to select an existing text string in the
drawing.
2. Allow the user to select a closed polyline.
3. Get the area of the closed polyline and send it to a string
variable.
4. Place a new line of text exactly one line of text below the one the user
picked. (this new line of text will match the properties of the previous
selected text.  The contents of this new line of text will be from the
string variable noted in #3 above.
I have almost all of this working except that I can not get the point to be
the text insertion point and I am not sure how to force the new line of text
onto the next line.  I also have not messed with the text properties.
Everything else works though. As it is now it wont insert the new line of text
because of the insertion point problem.
Here is the code:
Private Sub cmdRun_Click()
Dim Ent As AcadEntity
Dim Ent2 As AcadEntity
Dim Pt As Variant
Dim
Pt2 As Variant
Dim Cnt As Integer
Dim Cnt2 As Double
Dim strCnt As
String
Dim objText As acadText
Dim pointObj As AcadPoint
Dim objlayer
As AcadLayer
Dim strlayerName As String
Dim strText As String
On Error Resume Next
oldlayer =
ThisDrawing.ActiveLayer.Name
strlayerName = "NG_TEXT"
Set objlayer =
ThisDrawing.Layers(strlayerName)
If objlayer Is Nothing Then
    MsgBox "Layer '" &
strlayerName & "' does not exist. Please create it before
continuing."
    Exit Sub
Else
ThisDrawing.ActiveLayer = ThisDrawing.Layers("NG_TEXT")
Me.Hide
ThisDrawing.Utility.GetEntity Ent2, Pt2, "Select the matching Text: "
    Ent2.Highlight
True
        If Err
Then
Ent2.Highlight False
        End
If
    If
TypeOf Ent2 Is acadText Then
        Set
objText = Ent2
        Set Pt2 =
objText.insertionPoint 'HERE IS WHERE THE PROBLEM IS. i CAN NOT SEEM TO FIGURE
THIS OUT.
        Debug.Print
Ent2.ObjectName 'THE OBJECT NAME COMES UP AS AcDcText, SO IT IS ASIGNING IT
CORRECTLY.
Do
Me.Hide
ThisDrawing.Utility.GetEntity Ent,
Pt, "Select the desired polyline: "
    Ent.Highlight
True
        If Err
Then
Ent.Highlight
False
            If
ThisDrawing.GetVariable("errno") = "7"
Then
Err.Clear
Else
Err.Clear
Exit Do
        End
If
    If TypeOf Ent Is AcadLWPolyline
Then
        Set ObjPly =
Ent
            If
ObjPly.Closed = True
Then
            If
ObjPly.area > 0
Then
Cnt2 =
ObjPly.area
Cnt2 = Round(Cnt2,
0)
strCnt =
Cnt2
strCnt = Format(strCnt,
"##.0")
strCnt = Round(strCnt /
9)
            End
If
Else
'If the entity selected is not a closed polyline then send the following
message.
MsgBox "The Polyline you selected is not closed. Please close it before " &
_
"continuing. This command will exit.
            Exit
Do
            End
If
    Else
'If the entity selected is not a roompoly then
send the following message.
        MsgBox
"The object you selected is not a Polyline. This command will exit.
        Exit Do
Loop
strText = strCnt
Debug.Print strText
    If optLeft.Value = True
Then
        Set pointObj =
ThisDrawing.ModelSpace.AddPoint(Pt2)
pointObj.Color = acRed
        Set objText
= ThisDrawing.ModelSpace.AddText(strText, pointObj,
8)
        objText.Alignment =
acAlignmentLeft
objText.TextAlignmentPoint = pointObj
    If optMidCent.Value = True
Then
        Set pointObj =
        Set objText
8)
        objText.Alignment =
acAlignmentMiddleCenter
End Sub
Any suggestions?
Thanx,
Rob
Hi Rob,
Commented code follows
Dim Pt As Variant
Dim Pt2 As Variant
Dim Cnt As Integer
Dim Cnt2 As Double
Dim strCnt As String
Dim objText As AcadText
Dim objlayer As AcadLayer
'ADDED BECAUSE THEY HAD NOT BEEN DECLARED IN CODE
'IF YOU HAVE THESE LISTED AS PUBLIC MEMBERS OF THIS
'MODULE OR ANOTHER MODULE, COMMENT THESE LINES OUT
Dim oldlayer As String
Dim ObjPly As AcadLWPolyline
'////END DIMS //////
On Error GoTo Err_Control
'On Error Resume Next '
'LOOK AT HOW I HANDLED THIS...
oldlayer = ThisDrawing.ActiveLayer.Name
Set objlayer = ThisDrawing.Layers(strlayerName)
Me.Hide
Ent2.Highlight True
If Err Then
If TypeOf Ent2 Is AcadText Then
Set objText = Ent2
'HERE IS WHERE THE PROBLEM IS. i CAN NOT SEEM TO FIGURE THIS OUT.
'///Set Pt2 = objText.InsertionPoint////
'////SET IS FOR OBJECTS ONLY/////
'////I STOPPED CORRECTIONS HERE (ASIDE FROM THE ERROR HANDLER AT THE
'////END. WOULD YOU LIKE ME TO CONTINUE?
Do
Me.Hide
ThisDrawing.Utility.GetEntity Ent, Pt, "Select the desired polyline: "
Ent.Highlight True
If Err Then
Ent.Highlight False
If ThisDrawing.GetVariable("errno") = "7" Then
Err.Clear
Else
Err.Clear
Exit Do
If TypeOf Ent Is AcadLWPolyline Then
Set ObjPly = Ent
If ObjPly.Closed = True Then
If ObjPly.Area > 0 Then
Cnt2 = ObjPly.Area
'Cnt2 = Round(Cnt2, 0)
strCnt = Cnt2
strCnt = Format(strCnt, "##.0")
'strCnt = Round(strCnt / 9)
Else
message.
before " & _
"continuing. This command will exit. "
Exit Do
Else
'If the entity selected is not a roompoly then send the following message.
MsgBox "The object you selected is not a Polyline. This command will
exit. "
Exit Do
Loop
strText = strCnt
Debug.Print strText
If optLeft.Value = True Then
Set pointObj = ThisDrawing.ModelSpace.AddPoint(Pt2)
Set objText = ThisDrawing.ModelSpace.AddText(strText, pointObj, 8)
objText.Alignment = acAlignmentLeft
If optMidCent.Value = True Then
objText.Alignment = acAlignmentMiddleCenter
Exit_Here:
Exit Sub
Err_Control:
Select Case Err.Number
Case -2145386476
If ObjPly Is Nothing Then
MsgBox "Layer '" & strlayerName & _
"' does not exist. Please create it before continuing."
Resume Exit_Here
Case Else
MsgBox Err.Description
End Select
End Sub
Randall Rath
VB Design
http://www.vbdesign.net/cadpages/
Home of A Code A Day
Hi Randall,
You are more than welcome to continue if you wish. I enjoy seeing new ways
of doing things to make my life easier. I do still have one problem. I am
now getting the following error message after I select my polyline and click
enter:
Method 'Getentity' of object 'IAcadUtility' failed.
I press 'OK' and the macro stops. I am assuming this comes in from the
Err_Control routine you have added? Any suggestions as to why I am getting
this error?
Thanx for the help,
Rob
"Randall Rath" wrote in message
news:B6CDCB21ADA35ED9E92E3137F4EF0386@in.WebX.maYIadrTaRb...
> Hi Rob,
> Dim Pt As Variant
> Dim Pt2 As Variant
> Dim Cnt As Integer
> Dim Cnt2 As Double
> Me.Hide
> Ent2.Highlight True
> If Err Then
> End If
> Set objText = Ent2
> End If
> Do
> Me.Hide
> Ent.Highlight True
> If Err Then
> Ent.Highlight False
> Err.Clear
> Else
> Err.Clear
> Exit Do
> End If
> End If
> Set ObjPly = Ent
> Cnt2 = ObjPly.Area
> strCnt = Cnt2
> End If
> Else
> message.
> before " & _
> Exit Do
> End If
> Else
> exit. "
> Exit Do
> End If
> Loop
> strText = strCnt
> Debug.Print strText
> End If
> End If
> Exit_Here:
> Exit Sub
> Err_Control:
> Case -2145386476
> End If
> Resume Exit_Here
> Case Else
> End Select
> End Sub
> Randall Rath
> VB Design
Hi Rob,
Give this a spin..
Dim Pt As Variant
Dim Pt2 As Variant
Dim Cnt As Integer
Dim Cnt2 As Double
Dim varErr As Variant
Me.Hide
Ent2.Highlight True
Set objText = Ent2
'//BASED ON YOUR CODE, YOU WANT A SINGLE CLOSED POLYLINE TO MATCH
'//A SINGLE TEXT OBJECT, NO LOOP NEEDED OR THE LOOP SHOULD BEGIN
'//EARLIER TO ALLOW FOR THE SELECTION OF ANOTHER MATCHING TEXT AND
'//CLOSE LATER.
'Do
'Me.Hide
Ent.Highlight True
If Not Ent Is Nothing Then
Set ObjPly = Ent
Cnt2 = ObjPly.Area
strCnt = Cnt2
'//SELECTION IS DONE, RESET STATES
Ent.Highlight False
Else
message.
before " & _
'Exit Do
Else
exit. "
'Exit Do
'Loop
strText = strCnt
'Debug.Print strText
'//A POINT OBJECT IS NOT A VALID ARGUMENT, USE ITS INSERTION POINT.
'//IN THIS CASE I HAVE SIMPLY USED THE ORIGINAL POINT.
Pt2 = Ent2.InsertionPoint
'I HAVE USED .25 TO SET THE GAP, BUT YOU MAY WISH TO USE
'ANOTHER VALUE
Pt2(1) = Pt(1) - (8 + objText.Height + (8 * 0.25))
Debug.Print 8 * ThisDrawing.GetVariable("TSPACEFAC")
Set objText = ThisDrawing.ModelSpace.AddText(strText, Pt2, 8)
'///IF YOU USE ALIGNMENT LEFT THE ALIGNMENT POINT BECOMES
'///READ ONLY!
'/////objText.TextAlignmentPoint = Pt2
objText.Update
objText.Update
'////SHOW THE FORM AGAIN
Me.Show
Exit_Here:
Exit Sub
Err_Control:
Case -2145386476
Err.Clear
Resume Exit_Here
Case -2147352567
'varErr = ThisDrawing.GetVariable("LASTPROMPT")
'///THERE ARE MANY WAYS TO DEAL WITH THIS ERROR
'///SINCE YOU USED ERRNO'S VALUE IN YOUR CODE I
'///HAVE USED IT IN THE HANDLER.
If ThisDrawing.GetVariable("errno") <> "52" Then
Err.Clear
'MISSED PICK SEND THEM BACK
Resume
'//IF YOU WANT TO ALLOW EXIT WITH RIGHT CLICK
'//ADD A NEW PROPERTY TO THE THISDRAWING MODULE
'//THAT IS SET TO TRUE ON A RIGHT CLICK AND
'//CHECK IT HERE.
Else
Err.Clear
Resume Exit_Here
Case Else
End Select
End Sub
Randall Rath
VB Design
Home of the Wonder Llama
Hi again Randall,
I had to make one minor change (noted below) but it now works great. You
guys are all geniuses.
I just wanted to place the new text directly under the selected text, so I
just changed the following line:
to:
Pt2(1) = Pt2(1) - (8 + objText.Height + (8 * 0.25))
I do have one question though; what is the number in parenthesis after PT2?
i.e. Pt2(1)
I have never seen this before.
Thanx again Randall, I appreciate all of your help.
Rob
news:F1443998C8BDB4E45BE944B76E924D8C@in.WebX.maYIadrTaRb...
> Hi Rob,
> Give this a spin..
> Dim Pt As Variant
> Dim Pt2 As Variant
> Dim Cnt As Integer
> Dim Cnt2 As Double
> Me.Hide
> Ent2.Highlight True
> Set objText = Ent2
> End If
> '//CLOSE LATER.
> 'Do
> 'Me.Hide
> Ent.Highlight True
> Set ObjPly = Ent
> Cnt2 = ObjPly.Area
> strCnt = Cnt2
> Ent.Highlight False
> End If
> Else
> message.
> before " & _
> 'Exit Do
> End If
> Else
message.
will
> exit. "
> 'Exit Do
> End If
> End If
> 'Loop
> strText = strCnt
> 'ANOTHER VALUE
> '///READ ONLY!
> objText.Update
> End If
> objText.Update
> End If
> Me.Show
> Exit_Here:
> Exit Sub
> Err_Control:
> Case -2145386476
> End If
> Err.Clear
> Resume Exit_Here
> Case -2147352567
> Err.Clear
> Resume
> '//CHECK IT HERE.
> Else
> Err.Clear
> Resume Exit_Here
> End If
> Case Else
> End Select
> End Sub
> Randall Rath
> VB Design
Hi Rob,
After you write a couple million lines of this code, you will be a genius
too!
The Answer to your question:
PT2 has three elements:
PT2(0)
PT2(1)
PT2(2)
because it is a "variant array of doubles"
The values in the array are from the property:
Or in the simplest terms, the X,Y,Z of the insertion point of the selected
text in WCS values.
Randall Rath
