Getting coordinates of a selected PolyLine
Hi all
I have to get coordinates of a selected PolyLine by a SelectionSet.
I've already created a Selection set:
Set sset = ThisDrawing.SelectionSets.Add("SS_Preis_Poly")
sset.Select acSelectionSetPrevious
Now i only need the coordinates of the PolyLine... can someone help me?
Thanx!
Paul Blaszczyk
Hi!Paul Blaszczyk,
I hope the following VB code would serve your purpose.
Iam assuming you are using A2000 and the you want to get coordinates of
LWpolyline.
bye,
P.Murali
'_________________________begin______________________
Private Sub f_getCoord()
Dim a_app As AcadApplication
Dim a_doc As AcadDocument
Dim po_ss As AcadSelectionSet
Dim po_ent As AcadEntity
Dim po_arr As Variant
Dim pi_i As Integer
Dim po_ftype(0) As Integer
Dim po_fdata(0) As Variant
Set a_app = GetObject(, "Autocad.Application.15")
Set a_doc = a_app.Documents(0)
'set the selection set
'I have taken clue from Frank Oquendo reply
Set po_ss = a_doc.SelectionSets("ss1")
If Err Then Set po_ss = a_doc.SelectionSets.Add("ss1")
po_ss.Clear
'set the filter
po_ftype(0) = 0
po_fdata(0) = "Lwpolyline"
'select on the screen
po_ss.SelectOnScreen po_ftype, po_fdata
Set po_ent = po_ss.Item(0)
po_arr = po_ent.Coordinates
'prints to immediate window
'note that you should pick the elements in pairs to get the coordinates
'i.e po_arr(0) and po_arr(1) will get you the first coordinates of the first
vertex
For pi_i = 0 To UBound(po_arr)
Debug.Print po_arr(pi_i)
Next
End Sub
'__________________end of sub_________________________
Paul Blaszczyk <3d@alpharay.de> wrote in message
<381DBD2E.DFE03C2C@alpharay.de>...
>Hi all
>Thanx!
> Paul Blaszczyk
Murali P schrieb:
> Hi!Paul Blaszczyk,
> LWpolyline.
> bye,
> P.Murali
It works fine!! Thanx! 🙂
Paul Blaszczyk
I am having the same problem. It's a closed rectangle. When I try to get the
corners with :
dim boxmin (0 to 2) as double
dim boxmax (0 to 2) as double
mypline.getboundingbox boxmin, boxmax
I have plugged the line with mypline.delete just to make sure I have the
right entity, and it deletes it just fine. But all getboundingbox gets 0,0,0
for both corners. I had this program working in R14 but I'm having a lot of
trouble getting it to work in ACAD2K. I have painfully cobbled most of it
together but with this problem I can think of no where to turn. The program
seems perfectly happy with the 0s but if that's all I get I'm dead, and I'm
afraid I won't be able to reccommend that whe roll out the release to a
hundred users or whatever we have.
Is there a paper on all the changes that have made to this release of VBA
for AutoCAD?
I am having the same problem as Paul. The polygon is a rectangle so I can
get everything I need from the boundingbox. This code blithely returns 0,0,0
and 0,0,0 as the two corners, which ofcourse, neither is. Help!!!
mode = acSelectionSetCrossing
gpCode(0) = 0
dataValue(0) = "LWPOLYLINE"
Dim groupCode As Variant, dataCode As Variant
groupCode = gpCode
dataCode = dataValue
Set ssetObj = ThisDrawing.SelectionSets.Add("SSET")
ssetObj.Select mode, Pt1, Pt2, groupCode, dataCode
Dim ent As AcadLWPolyline
Dim BoxMin(0 To 2) As Double
Dim BoxMax(0 To 2) As Double
Set ent = ssetObj.item(0)
'ent.Delete [when this is online and the line below is not,
indeed, the correct pline is deleted...]
ent.GetBoundingBox BoxMin, BoxMax
Is there a paper that lists all the changes to VBA in ACAD2K? Converting all
our AutoCAD VB and VBA code is turning out to be unexpectly vexing. This
problem is a great example. We want to upgrade our 50-100 users but...
Help!
news:381DBD2E.DFE03C2C@alpharay.de...
> Hi all
> Thanx!
> Paul Blaszczyk
This is my code:
'---Selection set
Set poly_sset = ThisDrawing.SelectionSets.Add("SS_Price_Poly")
'Dim ftype(0) As Integer
Dim Fdata(0) As Variant
'---dxf code 0 = object type
ftype(0) = 0
'---filter for lwpolylines
Fdata(0) = "Lwpolyline"
'---get current selection
poly_sset.Select acSelectionSetPrevious, , , ftype, Fdata
'---is a polyline selected?
If poly_sset.Count <= 0 Then exit sub '---or put a error-msg here
'---if the user must select only one poly-line
If poly_sset.Count > 1 Then exit sub '---or errormsg "select only one
polyline"
Dim poly_ent As AcadEntity
Dim poly_coords As Variant '---or it is double?? variant
make no problems...
Set poly_ent = poly_sset.Item(0) '---if you are selecting more
than one polyline, you must create a loop and replace the (0) with a variable
poly_coords = poly_ent.Coordinates
'---numer of coords of poly
numer_of_points=ubound(poly_coords)-1 '---see NOTE !!
'---afert reading all the coordinates/polys delete the selection set---'
poly_sset.Clear
poly_sset.Delete
Set poly_sset = Nothing
End Sub
'---END---'
NOTE:
The last coordinate in he poly_coords() is the FIRST point of the poly-line!
(the position, at you begin drawin the polyline...and also the same as the first
point in the poly_coords() ).
I think, that this code is enought for you. 🙂
Bye
Paul Blaszczyk
My homepage: http://www.alpharay.de
Morgan Rauh wrotes:
> gpCode(0) = 0
> groupCode = gpCode
> Help!
> Thanks
Hi Murali P!
Your code solved me too. Thanks!
Ps to all- Sorry about my duplicate posting. Config problems...
Murali P wrote in message
news:7vrcnm$4j59@adesknews2.autodesk.com...
> Hi!Paul Blaszczyk,
> LWpolyline.
> bye,
> P.Murali
> Dim pi_i As Integer
> po_ss.Clear
> 'set the filter
> po_ftype(0) = 0
first
> vertex
> Next
> End Sub
> >Hi all
> >Thanx!
> > Paul Blaszczyk
