getpoint method
getpoint method
getpoint method
Every drawing wchich I write in VBA
and I want to start begins with command getpoint
I press F5 to compile. Autocad ask me
:please insert point
[ I use procedure
 pktP0 = .GetPoint(, vbCr & "Pick the start point: ")  ]
 and from that point i create other points using polarpoint method
isoA1hp1pos = .PolarPoint(pktP0, k0Deg, od140p)
Is there a possibility that this first point i set in vba program
and I don't have to every time click on the autocad screen indicate
first point   pktP0
I wrote program which doesn't work.Please correct him
Public Sub liniaz2punktow()
'I would like to set 1 point in Autocad and create another points
' from that point
' how to this this ?
With ThisDrawing.Utility
Dim Object As AcadPoint
Dim Here As Variant
Dim varP1 As Variant
Dim varP2 As Variant
Dim k0Deg As Double
Dim dbLpionL As Double 'podaje wartosc liczbowa
k0Deg = .AngleToReal("0d", acDegrees)
Here(0) = 2: Here(1) = 1: Here(2) = 0
dbLpionL = 500
varP2 = .PolarPoint(Here, k0Deg, dbLpionL)
ThisDrawing.ModelSpace.AddLine Here, varP2
End With
End Sub
Hallex
Probably you need to create separate function to add your entities
based on previously defined base point
Then you can call it in the main sub
Something like this
Public Function AddLineToSpace(firstPoint As Variant, angle As Double, dist As Double) As AcadLine
Dim secondPoint As Variant
With ThisDrawing
With .Utility
secondPoint = .PolarPoint(firstPoint, angle, dist)
End With
With .ModelSpace
Set AddLineToSpace = .AddLine(firstPoint, secondPoint)
End With
End With
End Function
Public Sub main()
Dim pi As Double
pi = Atn(1#) * 4
Dim p1(0 To 2) As Double
p1(0) = 0: p1(1) = 0: p1(2) = 0
Dim ang As Double
ang = pi / 4 '45 degrees
Dim dist As Double
dist = 1000#
Dim oLine As AcadLine
Set oLine = AddLineToSpace(p1, ang, dist)
'change some properties here
oLine.color = acRed
End Sub
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
thank You for help
it works
Hallex
You're welcome
~'J'~
