GetObject command
GetObject command
GetObject command
I am trying to use the following command to retrieve the currently active
Excel workbook.
Set ExcelServer = GetObject(, "Excel.Application")
ExcelServer.WindowState = XlWindowState.xlMinimized
According to the help file: "If the pathname argument is omitted, GetObject
returns a currently active object of the specified type" I find that if I
have an instance of Excel running and I execute the command it returns an
empty excel window, but not the current workbook, which is what I want.
What am i missing?
Getting the aplication doesn't necessarily get you the document. GetObject(,
"AutoCAD.Application") won't yield the active document in a running instance
of AutoCAD. See if you can use the ActiveWorkbook property to get your
document reference.
Visit AcadXtreme for a chance to win a copy of AutoCAD LT 2000
Contest ends 5/26/00
http://www.acadx.com
"John Wilde" wrote in message
news:ef1cfbe.-1@WebX.SaUCah8kaAW...
> Excel workbook.
GetObject
> What am i missing?
This works for me
'Set oExcelBook = oExcelApp.Workbooks.Add
Set oExcelSheet = oExcelApp.ActiveWorkbook.Sheets("Sheet1")
Gary
