GetEntity and GetObject methods
Here is a simple question.. Once I've selected an entity using GetEntity and GetObject, how do I determine what type of element I have whether it is an arc, line, spline, etc..? I'm looking to somehow filter the elements after it's been selected without using the selection sets methods. Is there a way? I would like to pass the entity to different areas in my code after I've determined what type of element the user has selected. Any help would be appreciated.
Dim Entity As AcadEntity
Dim PickPt As Variant
ThisDrawing.Utility.GetEntity Entity, PickPt
Select Case Entity.EntityName
Case "AcDbLine"
Utility.Prompt "This is a line"
Case "AcDbCircle"
Utility.Prompt "This is a circle"
Case "AcDbArc"
Utility.Prompt "This is an arc"
End Select
"Narith" wrote in message
news:f09fd58.-1@WebX.maYIadrTaRb...
be appreciated.
If your filtering structure isn't to complicated, you could us the
If...Then...Else statement TypeOf keyword.
If TypeOf oEnt Is AcadText Then
Bobby C. Jones
http://www.acadx.com
Thanks Tony,
I appreciate the help. I tried the routine and I am having trouble using the properties of the objects. It seems that the objects that are passed with this routine doesn't allow me to use the properties because it doesn't recognize the objects' properties. For example, after selecting the object, I was unable to access and compare the objects' x,y,c location. Have you experienced this problem before? Is there another routine that allows me to choose the entity and access it's properties as well?
Narith
