GetAsyncKeyState not working with Right Click
I thought this used to work
Now it doesn't seem to
What am I forgetting?
'(in AutoCad vba) but I should think vb would be similar except for the
KeyCodeConstants.vbKeyRButton reference ( = 2)
Declare Function GetAsyncKeyState Lib "user32" (ByVal vKey As Long) As
Integer
Private Const VK_RMC = KeyCodeConstants.vbKeyRButton
Public Function UserRightClicked() As Boolean
If (0 > GetAsyncKeyState(VK_RMC)) Then UserRightClicked = True
End Function
by doesn't seem to work, I mean when used in an error trap it says I didn't
hit right click when I did!
eg
On Error GoTo ErrCtl
....ask for selection from user
oDoc.Utility.GetEntity oEnt, vpt, "Pick text or block "
... if user hits right click selection fails with error sending us to ErrCtl
... I should get msgBox "right" but I don't....
ErrCtl:
If UserRightClicked Then
MsgBox"Right"
Else
MsgBox"Nope"
End if
"MP" wrote in message
news:5642331@discussion.autodesk.com...
'ok this seems to work in limited testing
'in the calling sub I need to hit GetAsyncKeyState to clear the value before
trying the line that could throw the error I'm trying to catch
'but that means I need to define GetAsyncKeyState in every scope I want to
use the test, or make it public in the .bas mod???
'is there a right way to do this?
Sub Main()
'initialize GetAsyncKeyState
Call GetAsyncKeyState(anyInteger)
On Error Resume Next' just for this example
oDoc.Utility.GetEntity oEnt, vpt, "Pick text or block"
If Err Then
MsgBox "Right"
etc
'in .Bas mod
Private Const VK_RBUTTON As Long = &H2&
If GetAsyncKeyState(VK_RBUTTON) = 1 Then UserRightClicked = True
End Function
