Get X,Y,Z coordinates from GetPoint
10:01 AM
I just started learning VB with AutoCAD last week, and am currently trying to create some programs for practice.
The program I am working on creates a rectangle by asking the user to define a starting point and entering the Length and Width of the rectangle.
So the first question is how do I create the StartPoint array ( the X,Y,Z coordinates) from the GetPoint method. This is what I have so far
____________________________
Public Sub InsertPt()
Dim pt1 As Variant
Dim dblStartPt(0 To 2) As Double
pt1 = ThisDrawing.Utility.GetPoint(, "Pick the Starting point: ")
dblStartPt(0) = pt1(0): dblStartPt(1) = pt1(1): dblStartPt(2) = pt1(2)
End Sub
The second question is where should I place this code in the program. Can I insert this in the commandbutton code that draws the box? Currently, when I do this, the user is not prompted to select a starting point. The program automatically asks for the rectangle dimensions. Do I insert the code in a standard module and specify it as public like I did above? If so, will the code in the commandbutton be able to retrieve the starting point information.
Thank you.
Best,
Kevin
Dim pt1 As Variant
End Sub
Thank you.
Best,
Kevin
