Get the current view
Message 1 of 10
Can some one tell me how to get the current view (i.e.
Top,Bottom,Left,Right,Front,Back)
Andy
Replies (9)
Message 2 of 10
do you mean in model space, what direction you're looking from? or are you
talking about some paperspace viewports? is it vanilla autocad you're
working in, or one of the vertical products?
Kevin
"Andrew Elmore" wrote in message
news:E3266AC8D01EABE8C55AB664D697917E@in.WebX.maYIadrTaRb...
> Andy
Message 3 of 10
When in modelspace and/or paperspace. if I change the current view to say
front then have have a message box promt the current view that I'm looking
from. If I can get that then I can figure the rest of the code out. (I'm
going to have layers frozen and unfrozen depending on the current view)
I'm useing ADT 2004. for this program.
Andy
"Kevin Terry" wrote in message
news:204F1DFD122530ADC8D79695F6B9E4D0@in.WebX.maYIadrTaRb...
> Kevin
> > Andy
Message 4 of 10
Don't know if this will be of any help to you, but check out the sample
installed on your computer called example_events.DVB (C:\Program
Files\MDT6\Sample\VBA\example_events.DVB on mine).
Kevin
news:83AF7B14E59F09B1C25A18CE77DB8E59@in.WebX.maYIadrTaRb...
> Thanks,
> Andy
you
> > Kevin
> > > Andy
Message 5 of 10
I don't Have that one on my computer could you post it please.
Andy
news:A5F1E3BE91F6AC50BF2A7D18E8DA5334@in.WebX.maYIadrTaRb...
> Kevin
say
looking
> > Thanks,
> > Andy
> you
> > > Kevin
> > > > Andy
Message 6 of 10
do a search on your hard drive or installation cd - it's provided with your
standard licensed copy of whatever autocad product you have.
Kevin
news:524B4125851A94D71B8BDA23A81FA535@in.WebX.maYIadrTaRb...
> Andy
> > Kevin
> say
> looking
(I'm
view)
> > > Thanks,
> > > Andy
are
> > you
you're
> > > > Kevin
> > > > > Andy
Message 7 of 10
I searched the hard drive ADT,ACAD and no file close to example_Events
Andy
news:54BAD627AB2644108D51C70DBBBF30C1@in.WebX.maYIadrTaRb...
your
> Kevin
> > Andy
sample
> > > Kevin
to
> > say
> > looking
> (I'm
> view)
> > > > Thanks,
> > > > Andy
> are
> > > you
> you're
> > > > > Kevin
> > > > > > Andy
Message 8 of 10
Can get the VBA to get the command -View; but I can't get what the user
selected top,bot,sw, ect...
anybody know how to get this.
Andy
your
> Kevin
> > Andy
sample
> > > Kevin
to
> > say
> > looking
> (I'm
> view)
> > > > Thanks,
> > > > Andy
> are
> > > you
> you're
> > > > > Kevin
> > > > > > Andy
Message 9 of 10
You could do something brute-force like the following. Set the views
yourself and check the variable manually to populate your If...Then (If you
want the function to work when someone chooses their view relative to the
UCS, you'd need to add another flag to the sub). The 'eq' function is just
to get past the computer's exactness. This is a non-working example.
Good luck,
James
Function WhichViewActive() as string
dim varViewDir as variant
varViewDir = getVariable("VIEWDIR")
Dim varVD_WCS As Variant 'view direction vector, translated from UCS to
WCS
varVD_WCS = ThisDrawing.Utility.TranslateCoordinates(varVD, acUCS,
acWorld, True)
vX = varVD_WCS (0)
vY = varVD_WCS (1)
vZ = varVD_WCS (2)
if EQ(vX,0,0.01) and EQ(vY,0,0.01) and EQ(vZ,-1,0.01) then
WhichViewActive = "TOP"
elseif EQ(vX,0,0.01) and ...
WhichViewActive = ...
else
WhichViewActive = "UNKNOWN"
endif
End Function
Public Function eq(val1 As Double, val2 As Double, fuzz As Double) As
Boolean
'function courtesy of www.acadx.com
eq = Abs(val1 - val2) <= fuzz
End Function
Message 10 of 10
Thanks James
"James Belshan" wrote in message
news:DFEEFA41815B377438AEE2E356B49072@in.WebX.maYIadrTaRb...
you
just
> Good luck,
> James
to
> WCS
> acWorld, True)
> vX = varVD_WCS (0)
> vY = varVD_WCS (1)
> vZ = varVD_WCS (2)
> else
> endif
> End Function
> Boolean
> End Function
