Get Text Question
Get Text Question
Get Text Question
Can someone tell me how to select a single line of text in AutoCad and make it display in my VBFORM.TEXT1.TEXT?
I figured out how to get the text from AutoCad and store it to a textstring. I named the textstring TEXTSELECTED. I would like to search the textstring and turn all of the "N" into "S", all of the "S" into "N", all of the "E" into "W" and all of the "W" into "E" Laurie posted a very good idea earlier but it won't work with all autocad versions. Can someone help. My code to get the textstring is as follows:
Dim acadApp As Object
Set acadApp = GetObject(, "AutoCAD.application")
acadApp.Application.Visible = True
DoEvents
Set Thisdrawing = acadApp.activedocument
DoEvents
DoEvents
Dim activedocument As Object
DoEvents
ForceSwitchtoAutoCAD
Dim entText As Object
Dim AcadText As Object
Dim AcadMText As Object
Dim TextString As String
Dim textselected As String
Thisdrawing.Utility.GetEntity entText, vPt, vbCr & "Select AutoCad Text:"
'If TypeOf entText Is AcDbText Or TypeOf entText Is AcDbMText Then
textselected = entText.TextString
Please help.
I figured it out. Just add this code to the bottom of the previous code. But I have one more question...
textselected = Replace(textselected, "N", "XX")
textselected = Replace(textselected, "S", "VVV")
textselected = Replace(textselected, "E", "QQQQ")
textselected = Replace(textselected, "W", "ZZZZZ")
textselected = Replace(textselected, "XX", "S")
textselected = Replace(textselected, "VVV", "N")
textselected = Replace(textselected, "QQQQ", "W")
textselected = Replace(textselected, "ZZZZZ", "E")
I need to update the text that I selected in AutoCad with textselected????????????
wrote in message
news:5865163@discussion.autodesk.com...
entText.TextString = textselected
entText.Update
hth
mark
Thanks Mark!
