Get point from dist
Get point from dist
dragnsbld
Get point from dist
dragnsbld
Does anyone have an idea on how to get a point from a distance along an object within VBA (without using LISP). I am using VBA inside of Arch. Desktop. Message was edited by: Dragnsbld
Each object has to be treated differently.
In the simplest case of a line you can get the end points and the angle from
the X axis, then use the polarpoint API command
Regards
Laurie Comerford
wrote in message news:5927039@discussion.autodesk.com...
Desktop.
dragnsbld
Yeah there lies my problem. If I have an arc the arc needs to be changed to a LWPolyline and joined with a mated line before I begin the point location. Then a Perpendicular line from there needs to be added to an offset copy of the first line, then another offset copy needs to be added and the perpendicular line needs to be extended to the second line. This then creates a squared end (1 side of a rectangle) and the other side gets angled to form an arrow. I only have 2 problems doing this, the first is the reason for this reply. the second is creating the second perpendicular line using VB and not LISP.
With this level of complexity it would help it you Publish to DWF format a
graphic of what you are trying to achieve and post your lisp file.
That way the person who helps you will have better understanding of your
needs.
Regards
Laurie Comerford
wrote in message news:5927642@discussion.autodesk.com...
VB and not LISP.
Unfortunately, VBA is not equipped to do this, but the vlax-curve-* methods can do it. There's always the usual kludge of calling LISP code from VBA, if that sort of thing suits you.
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD 2009
Supporting AutoCAD 2000 through 2009
http://www.acadxtabs.com
Introducing AcadXTabs 2010:
http://www.caddzone.com/acadxtabs/AcadXTabs2010.htm
its possible for a polyline of course with trigonometry. i fudged it once with sendcommand & Length command. i.e.
Set tmpArc = ThisDrawing.ModelSpace.AddArc(myArc.center, myArc.radius, myArc.StartAngle, myArc.EndAngle)
ThisDrawing.SendCommand ("len" & vbCr & "t" & vbCr & DistanceTxt & vbCr & myArcPt(0) & "," & myArcPt(1) & vbCr & vbCr)
endPt = tmpArc.StartPoint
tmpArc.delete
dragnsbld
I think this method may work the best for me right now cadger. Later I will sit down with a friend of mine and see about writing a new class/object model to do just this. That may not be for a few weeks however since this project has a tight deadline.
Thanks everyone for you input.
