Get ExtLinePoints from Dimension
Hi I tried to get the ExtLinePoints from a Dimension with the following code but I coudn't find it. Any Idea how I can get it!
Dim objSelSet As AcadSelectionSet
Dim objDim As AcadDimension
Dim pnt As Variant
Set objSelSet = ThisDrawing.SelectionSets.Add("dime")
intType(0) = 0
varData(0) = "DIMENSION"
objSelSet.Select acSelectionSetAll, , , intType, varData
For Each objDim In objSelSet
pnt = objDim.TextPosition
Next
objSelSet.Delete
adam.nagy
Autodesk Support
Autodesk Support
Hi there,
You should check the exact type of the dimension you get back from the selection.
It could be e.g. AcadDimAligned, which does have ExtLine properties
I hope this helps.
Adam Nagy
Autodesk Developer Network
Adam Nagy
Autodesk Platform Services
