Get Dim Text as 'Rendered' by AutoCAD
Is it possible to get the text from a dimension as it would be displayed on the screen by AutoCAD so I can then set the textoverride?
I have tried for the last two days and have not had any success. I can loop thru the dim entities/dim blocks and find the mtext, get the measured value and set the textoverride - no problem
What I am having trouble with are dims that have an existing override '<>.38 TYP', a measured distance of .3788831 and a dimscale that does not display any decimal places.
AutoCAD properly displays '.38 TYP' but I need to put that into the textoverrride instead of '<>.38 TYP'
Bill
Hello All,
I do quite a bit of VB programming - not a lot with AutoCAD - so is this just not possible/reasonable - or - is it so simple I should be embarrassed for asking???
I am currently looping thru all entities and if the current entity is a dim, it is passed to a function that builds a text string that is what (I hope) the dim would look like on screen:
DimMeasurement$ = CStr(CurrDim.Measurement)
If CurrDim.SuppressLeadingZeros = True Then
FormatLeadingZero$ = ""
Else
FormatLeadingZero$ = "0"
Select Case CurrDim.PrimaryUnitsPrecision
Case acDimPrecisionZero
FormatDimPrecision$ = ""
Case acDimPrecisionOne
FormatDimPrecision$ = "0"
Case acDimPrecisionTwo
FormatDimPrecision$ = "00"
Case acDimPrecisionThree
FormatDimPrecision$ = "000"
Case acDimPrecisionFour
FormatDimPrecision$ = "0000"
Case acDimPrecisionFive
FormatDimPrecision$ = "00000"
Case acDimPrecisionSix
FormatDimPrecision$ = "000000"
Case acDimPrecisionSeven
FormatDimPrecision$ = "0000000"
Case acDimPrecisionEight
FormatDimPrecision$ = "00000000"
Case Else
End Select
NewDimText$ = Format(DimMeasurement, FormatLeadingZero$ & DecimalSep$ & FormatDimPrecision$)
I know that Angular Dims will need special handling to format deg/min/sec's - but does this seem like a reasonable approach?
Bill
