get and use extended ent data?
mdhutchinson
Advisor Advisor
mdhutchinson
I've done lisp for a long time ... and am trying to learn VBA - but am finding it difficult ...
The extended data in lisp looks like the following...
(-3 ("MyApplication" (1002 . "{")
(1011 522.909 -15481.2 0.0) (1011 17682.1 -15450.2 0.0) (1011 17679.0 -13712.5
0.0) (1011 519.768 -13743.5 0.0) (1002 . "}"))))
In VBA I am having a difficult time getting the data ... the GetXData call runs without error ...
but I can't seem to get a look at the extended ent data when I toggle a breakpoint there ...
What I trying to do is to extract this ext data, pull out a window defined by the four 1011 coordinates and use them in
a selection to grab other entities that lay within the window.
I can do this in lisp very easy ... but in VBA I find it a struggle.
Can someone give me a leg up?
Dim xdata As Variant
Dim xtype As Variant
Dim blkObj As AcadBlockReference
blkObj.GetXData "MyApplication", xtype, xdata
xtype will be an array the holds the dxf-style codes of the XData. xdata is
an array that holds the actual data stored with each dxf-style code.
xtype(0) = 1001
xdata(0) = "My data"
R. Robert Bell
wrote in message news:5421454@discussion.autodesk.com...
17679.0 -13712.5
mdhutchinson
xtype(2) returns 1011 the group code for the coodinate...
but when I do xdata(2) I get a type mismatch error...
... a little more help please?
More code would help.
Are you providing a variant for the 3D point you are attempting to retrieve?
R. Robert Bell
wrote in message news:5421498@discussion.autodesk.com...
Since the 1011 group holds a point's coordinates, the xdata(2) will be
returning a 3 element array(Variant).......
If IsArray(xData(2)) Then
Debug.Print "The X value = " & xData(2)(0)
mdhutchinson
Jeff M... Thanks big time...
I want to store an array of variants... that will be a suitable for SelectBytPolygon method... (4 points that form the verts of a polygon)
Would the below be a way to do this then?
Dim Vertices(0 To 11) As Variant
For j = 0 To UBound(xtype)
If IsArray(xdata(j)) Then
Vertices(k) = xdata(j)(0)
k = k + 1
Vertices(k) = xdata(j)(1)
k = k + 1
Vertices(k) = xdata(j)(2)
k = k + 1
Next
mdhutchinson
This looks like it will work...
but is it a eloquent way to do it?
I haven't tried the SelectByPolygon method yet...
