Get and set layerstate to viewport
stefanveurink68AXD
stefanveurink68AXD
Dear everybody.
What I want is user to select a viewport, then get that viewports layer-settings (vpfreeze, vpcolor, vplineweight), and set it to all viewports in the drawing with width smaller 250.
this is the code i got:
ThisDrawing.Utility.GetEntity VP, a, "Select source-viewport:"
''''NEED TO GET LAYERSTATE HERE
For Each aLayout In ThisDrawing.Layouts
    If aLayout.Name <> "Model" Then
        For Each aEntity In aLayout.Block
            If TypeOf aEntity Is AcadPViewport Then
                aEntity.GetBoundingBox minpunt, maxpunt
                If maxpunt(0) - minpunt(0) < 250 Then
                ''''NEED TO SET LAYERSTATE HERE
            enidf
        Next
Next
Anyone who can get me going with getting and setting the layerstate? Cause I can't figure out how to do this or where to start.
Any help would be appreciated.
grobnik
@stefanveurink68AXD
I'm not so expert with Layerstate but by the way I found something that seems could solve your issue:
See link and code below
https://help.autodesk.com/view/OARX/2019/ENU/?guid=GUID-52B191C9-B183-4B20-96FD-AE3F44FA9AFA
Sub Ch4_ListStates()
  On Error Resume Next
  Dim oLSMDict As AcadDictionary
  Dim XRec As Object
  Dim layerstateNames As String
  layerstateNames = ""
  ' Get the ACAD_LAYERSTATES dictionary, which is in the
  ' extension dictionary in the Layers object.
 Dim oLSM As AcadLayerStateManager
Set oLSM = ThisDrawing.Application.GetInterfaceObject("AutoCAD.AcadLayerStateManager." & Left(AcadApplication.Version, 2))
Set oLSMDict = ThisDrawing.Layers.GetExtensionDictionary.Item("ACAD_LAYERSTATES")
  ' List the name of each saved layer setting. Settings are
  ' stored as XRecords in the dictionary.
  For Each XRec In oLSMDict
   layerstateNames = layerstateNames + XRec.Name + vbCrLf
  Next XRec
  MsgBox "The saved layer settings in this drawing are: " + vbCrLf + layerstateNames
  oLSM.SetDatabase ThisDrawing.Database
End Sub
' Restore the color and linetype settings of a drawing's layers
'Assuming that the color and linetype settings of the layers in the current drawing were previously saved under the name “ColorLinetype”, the following code resets the color and linetype settings of each layer in the drawing to the value they had when “ColorLinetype” was saved.
Sub Ch4_RestoreLayerSettings()
  oLSM.Restore "ColorLinetype"
End Sub
stefanveurink68AXD
Thanks, this is helpful, but what i am missing (and am struggling with since the start, also when trying to make a code in .NET) is linking the layerstate to a viewport.
Your code just sets the layers in the DRAWING itself back to a previously saved layerstate.
What i need is set the layers in a certain VIEWPORT to a (saved) layerstate.
Wondering if this is even possible in VBA or C#, because i don't see the terms VPcolor, VPfreeze, etcetera don't show up anywhere. Still would surprise me if really not possible, cause in Autocad this is possible since as long as I use the program. So, still got the question: anyone knows how to link this the dictonairy to a viewport?
