form focus and acadview help
how do you figure out if the view is for modelspace or paperspace??
i have this setup so when you dblclk on a name it changes your view to that
name. but i also want the form to give autocad focus. any suggestions? (vba)
Jaime
Jaime had this to say:
One way would be to use VLAX to query the entity data for your view:
http://code.acadx.com/visualbasic/024.htm
Another would be to use vbXtender's ViewEx class (use the link in my
signature to get a copy):
Dim vx As ViewEx
Set vx = Application.GetInterfaceObject("vbXtender.ViewEx")
Set vx.View = myView
Debug.Print vx.PaperSpace
> to that name. but i also want the form to give autocad focus. any
> suggestions? (vba)
Are you using the AcFocusCtrl library on your form? If so, set KeepFocus to
false and AutoCAD will take the focus back all by itself. Otherwise, try
AppActivate.
"If you want to be somebody else change your mind"
http://www.acadx.com
http://vbxtender.sourceforge.net
was hoping there was away to do it without creating alot of support code 😕
maybe ill just rewrite the whole thing in vlisp.
Jaime
> code 😕 maybe ill just rewrite the whole thing in vlisp.
I'm not sure a DCL file would not qualify as "alot of support code".
well my goal here was to do it ALL in vba altho i do use
thisdrawing.sendcommand for some stuff and that just bugs the (edited)outta me
Jaime
