forcing vba to wait
forcing vba to wait
forcing vba to wait
I have a VBA program that opens a new drawing and then prompts the user to select a point on the screen. Everything works fine but when a new drawing is opened several programs and events (ie Softdesk and VBA) run and my program keeps asking for a point causing errors. Is it possible to wait for everything to load before it asks for the point?
Thank you in advance.
Jamie Gamauf
I'm going to be watching this post and I hope you get a good response because I had the same problem. My solution is klunky but it worked for me. I'd certainly think that there's a better way...But, here's what I did. I had my VB code write an entry to the registry. Just a flag that I set to "0". Then, in my MNL and other routines that tried to load, I had them check that setting, and bypass whatever they were trying to do until the value became "1". Then once everything ran it's course and my VB finished up, I had the code set the value to "1" and this time when the drawing opened, the other routines could do their thing.
Hope this helps, or at least sparks another idea,
Guy
Jamie,
You might want to check out using the IsQuiecent
property of the AcadState object. There is an example in the AutoCAD 2000i
help.
Wayne
style="BORDER-LEFT: #000000 2px solid; MARGIN-LEFT: 5px; MARGIN-RIGHT: 0px; PADDING-LEFT: 5px; PADDING-RIGHT: 0px">
I
Jamie Gamauf
