for each.. next alternative to loop through modelspace entities
GilesPhillips
GilesPhillips
I've got some code that currently uses a for each Entity in AcadDocument.modelspace .... next Entity type construct to loop through modelspace entities in a specified document.
However a rewrite has it replacing some pesky mtext with dtext, which then crashes the for-each loop as the next entity in it's list has been deleted.
Is there a better way to do this?- I need to loop through all the modelspace block references (not fussed about the rest, the text is picked up and modified as a side function related to the blocks).  I can't use selection sets as this code needs to run independently of what's on the screen.
Can I rephrase my for-each loop to be more resilient to stuff getting deleted off it's list?
thanks for any thoughts..
G
ACad, MEP, Revit, 3DS Max
norman.yuan
You only loop through ModelSpace once to IDENTIFY your target entities and store them aside, say, an array. After the loop, as long as the array is not empty, you do whatever with the entities in the array. Code would be like:
Dim i As Integer
Dim blks() As AcadBlockReference
Dim ent As AcadEntity
Dim blk As AcadBlockReference
For Each ent In ThisDrawing.ModelSpace
    If TypeOf ent Is AcadBlockReference Then
         Set blk = ent
         '' You then test if the block is the target block, likely by its name
         If UCase(ent.EffectiveName)="MyTargetBlock" Then
               Redim Preserve blks(i)
               set blks(i) = blk
               i = i + 1
Next
If i > 0 Then
   DoSomethingWithFoundBlocks blks
Norman Yuan
Drive CAD With Code
GilesPhillips
Hi Norman - thanks for this.
I think my code needs a bit of an efficiency drive- putting the block references into an array for later processing sounds like the right approach.
G
