First time for error handling... will this work
mdhutchinson
Advisor Advisor
mdhutchinson
In my application a particular file is deleted with a click event of a check box.
Is this proper error handling?
On Error Resume Next
Kill (strPCNlockFile)
The error would happen if for some reason the file doesn't exist.
Hi Hutch,
It depends on how you need to handle other errors.
See the posts above for a Fileexists method which you could use to ensure
you don't create an error from the Kill function.
Or you could add an additional line to the code:
On Error Goto ErrorHandler
or
On Error Goto 0
etc.
Laurie Comerford
CADApps
www.cadapps.com.au
www.civil3Dtools.com
wrote in message news:5450896@discussion.autodesk.com...
box.
Why not test for the file before using the kill statement? ie:
if dir$(strPCNlockFile) <> "" then
else
msgbox "File doesn't exist"
end if
In general I think you should try to test for all potential problems you can
think of, and then a generic error handler for everything you don't think of
something like:
Sub Test()
On Error Goto Error:
else
msgbox "File " & strPCNlockFile & " doesn't exist"
end if
Exit Sub
Error:
msgbox "Error " & Err.Number & " (Err.Description) & " occured."
End Sub
box.
