finding a block by blockname
Can i find a block with blockname, without creating a selection set of all
object and search for a block and then the specific blockname. With a big
drawing this will take to much time.
Please give me advise
Ysbrand Haagsma
The Netherlands
On Error Resume Next
Set MyBlock = ThisDrawing.Blocks.Item(BlockName)
If MyBlock Is Nothing Then (block was not found) Else (block was found)
I haven't checked the syntax...
Rune Wold
System Analyst
Engineering Systems
rune@engsys.no
"Ysbrand Haagsma" wrote in message
news:3C99B163870210F9BFAC333A21BC1A71@in.WebX.maYIadrTaRb...
> Thanks
> Ysbrand Haagsma
> The Netherlands
With this command i can't read the attributes for specific block. The syntax
does work, but does only connect to the blocks list anf not blocks on the
drawing.
> Rune Wold
> System Analyst
> Engineering Systems
> rune@engsys.no
all
big
> > Thanks
> > Ysbrand Haagsma
> > The Netherlands
The code I wrote will find the block, or the block definition. What you want
is the block reference.
You could check whether it's quicker to loop through the items in modelspace
(assuming, of course, that the block references you are looking for are in
modelspace).
Dim entBlk As AcadEntity
For Each entBlk In ThisDrawing.ModelSpace
If TypeOf entBlk Is AcadBlockReference Then
If entBlk.Name = "MyBlockName" Then MsgBox "Found block reference"
Next
Rune Wold
System Analyst
Engineering Systems
rune@engsys.no
thanx,
This is working fast.
i made first a selection set of al objects and looped through the selection
set. but this is working faster.
"Rune Wold" wrote in message
news:734FA6F72CF68A13386ACB782793B8DD@in.WebX.maYIadrTaRb...
want
modelspace
> modelspace).
> End If
> Next
> Rune Wold
> System Analyst
> Engineering Systems
> rune@engsys.no
Looping over every entity seems wasteful, you can create a selection set containing only blocks with a certain name using Filters. Refer to the attached file. This also filters out to blocks with attributes.
