filtering the selection set object
Hi, I have question in filtering the selection set object.
What is want is, i have a selectionset (selecton screen type) objects in that i have to filter first line, then from that collection again i want to filter the horizontal and vertical lines and put those two different items in different arrays? is it possible ? i have tried a code solme thing like this,
For i = 0 To ss.Count - 1
If TypeOf ss.Item(i) Is AcadLine Then
Set lin = ss.Item(i)
ang = lin.Angle
If ang < 3.25 Then
ADD TO AN ARRAY
Else
ADD TO AN ARRAY
Thanks in advance.
Arun
sounds like it would work
are you saying it didn't?
mark
I have question in filtering the selection set object. What is want is, i have
possible ? i have tried a code solme thing like this, For i = 0 To ss.Count -
1 If TypeOf ss.Item(i) Is AcadLine Then Set lin = ss.Item(i) ang = lin.Angle
If ang < 3.25 Then ADD TO AN ARRAY Else ADD TO AN ARRAY End
If End If Thanks in advance. Arun
the array what i added, return nothing . so, If possible can you update the code? and reply me. Thanks in advance.
i got the answer, it is working fine now, thnx MP
