Filtering lines and polylines
Hi there.
I´m trying to use a selectionset with a filter to lines and polylines, but it just don´t work. Can someone help me?
I´m doing it like that:
Dim sst As AcadSelectionSet
Dim filtertype(2) As Integer
Dim filterdata(2) As Variant
filtertype(0) = 0
filterdata(0) = "Polyline,LWPolyline,Line"
sst.SelectOnScreen filtertype, filterdata
But then i get error 91 = "Object variable or With block variable not set"
Thanks!
Your missing a line like this that initialises the selection set object. The
Dim statement just allocates memory for it.
Set sst = ThisDrawing.SelectionSets("sst")
"dangirotto" wrote in message news:5842617@discussion.autodesk.com...
Hi there.
filtertype(0) = 0
Thanks!
Thanks!!
I added the line
Set sst = ThisDrawing.SelectionSets.Add("sst")
and it solved my problems..
but it doesn´t select any of my lwpolylines..
do you know what might be the problems?
Try : sst.Select acSelectionSetAll, , , filtertype, filterdata
"dangirotto" wrote in message news:5842627@discussion.autodesk.com...
Thanks!!
I added the line
The below sub will allow selection of lines, polylines and lwpolylines. The function ASet will check for the selection set and remove it if it exist and then create it and return it to the calling sub
Sub GetPolyLwPolyLine()
Dim ssetA As AcadSelectionSet
Dim gpCode(2) As Integer
Dim dataValue(2) As Variant
Dim groupCode As Variant
Dim dataCode As Variant
gpCode(0) = 0
dataValue(0) = "LINE"
gpCode(1) = 0
dataValue(1) = "LWPOLYLINE"
gpCode(2) = 0
dataValue(2) = "POLYLINE"
groupCode = gpCode
dataCode = dataValue
Set ssetA = Aset("POLY")
ssetA.SelectOnScreen groupCode, dataCode
While ssetA.Count
ssetA.Highlight True
Wend
ssetA.Delete
End Sub
Function Aset(iSSetName As String) As AcadSelectionSet
On Error Resume Next
Set ssetA = ThisDrawing.SelectionSets.Add(iSSetName)
If Err.Number <> 0 Then
Set ssetA = ThisDrawing.SelectionSets(iSSetName)
ssetA.Delete
Err.Clear
On Error GoTo 0
Set Aset = ssetA
End Function
