File List with VBA
File List with VBA
Message 1 of 12
File List with VBA
Hi Everyone,
I have a requirement to obtain all of the .dwg files in the folder
containing the active drawing and all sub directories thereunder. I have am
currently using "sendcommand", shelling to Dos, creating a temp text file in
the temp directory, and then reading the file back in with VBA. Although it
is working well, its cumbersome and hacked to say the least. I have several
other apps in full VB that use the file controls as demonstrated in the
"winseek" app. The file controls don't seem to be available in VBA. Does
anyone have or know of a more elegant method of obtaining a file list from a
given dir and all its sub dirs?
Thanks in Advance,
Gary
Replies (11)
Message 2 of 12
Are you trying to browse or are you needing the names of the files and
directories for some other process?
If you want to browse your system, you can use the common dialog box
(comdlg32.ocx) This will give you Microsoft's explorer type browsing dialog
box.
If you need the names of all the files and directories for some other
processing, you can use the dir function.
Hope this gets you going in the right direction.
Mark Smith
Air Gage Co.
masmith@airgage.com
Message 3 of 12
Mark,
Thanks for your interest. I am trying to get all of the files in the
directory that contains the active drawing and/or any and all sub
directories under that directory with no user intervention. I am already
using the dir function to get all the files in the directory containing the
active drawing (one of the options in the program). I started looking into
recursive calls with dir but it started getting very involved. A similar
post to this suggested using dos. At the time I didn't want to re-invent the
wheel so I went with the dos stuff. I would like to replace it something
thats works entirely within VBA.
Gary
Message 4 of 12
VBDesign has some code up at
http://vbdesign.hypermart.net/cadpages/get_file_names.htm that may get you
closer.
-- Walter -- http://www.ActiveDwg.com --
Gary McMaster wrote in message
news:ef29a66.1@WebX.SaUCah8kaAW...
> Mark,
the
the
> Gary
Message 5 of 12
Gary,
Here is some code I use to accomplish this task. It you pass the function a
string containing the path you want to start with it will put all *.dwg
files below that path in a listbox. Maybe you can modify it to meet your
needs.
John
Public MyPath as String
Public Sub GetSubDirs(MyPathInput As String)
Dim NumOfDwgFiles As Integer
Dim NumOfDirectories As Integer
Dim MyName As String
Dim i As Integer, n As Integer
Dim StartDirectory As String
'Assign the MyPath variable. If we are in the base directory (eg, C:\) then
dont append '\'
If Right(MyPathInput, 1) <> "\" Then MyPath = MyPathInput & "\" Else MyPath
= MyPathInput
StartDirectory = MyPath
'Find the number of directories in MyPath
i = 0
MyName = Dir(MyPath, vbDirectory)
Do While MyName <> ""
If MyName <> "." And MyName <> ".." Then
If (GetAttr(MyPath & MyName) And vbDirectory) = vbDirectory Then
i = i + 1
MyName = Dir
Loop
NumOfDirectories = i
If NumOfDirectories > 0 Then
ReDim dirs(0 To NumOfDirectories - 1) As String
i = 0
'Populate the dirs array with the names of directories in MyPath
MyName = Dir(MyPath, vbDirectory) ' Retrieve the first entry.
Do While MyName <> "" ' Start the loop.
'Use bitwise comparison to make sure MyName is a directory.
dirs(i) = MyPath & MyName ' Store entry only if it
represents a directory.
i = i + 1
MyName = Dir ' Get next entry.
Loop
'Find the number of DWG files in MyPath
NumOfDwgFiles = 0
i = 0
MyName = Dir(MyPath + "*.dwg", vbNormal) 'Tell the Dir command what to
look for
Do While MyName <> "" 'Counts the number of files in this directory that
fit above description
MyName = Dir
i = i + 1
Loop
NumOfDwgFiles = i
If NumOfDwgFiles > 0 Then
ReDim files(0 To NumOfDwgFiles - 1) As String 'An array to store the
names of the files
i = 0
' Populate the file array with the names of files in MyPath
MyName = Dir(MyPath + "*.dwg", vbNormal) ' Retrieve the first entry.
files(i) = MyPath & MyName
i = i + 1
Loop
'We are adding all DWG files to ListBox2
For i = 0 To (NumOfDwgFiles - 1)
ListBox2.AddItem files(i)
Next i
'Call the GetSubDirs routine (recursivly) for each subdirectory in MyPath.
The base case (when
'the function returns to the routine that called it) is when the For loop is
finished
For n = 0 To NumOfDirectories - 1
GetSubDirs (dirs(n))
Next n
MyPath = StartDirectory
Exit Sub
End Sub
"Gary McMaster" wrote in message
> Mark,
the
the
> Gary
Message 6 of 12
Gary,
Here is what I use in a project that allows me to browse for a file:
Private Sub cmdBrowse_Click()
'This sub will open the common dialog box and enable the user to browse for
a file
'It will then set the browse file flag to true so the cmdInsert sub will
know that
'it will need to process the file name differently (It will not be able to
access the
'record set for the file name.)
With frmCatalog.comDlg
.DefaultExt = "dwg"
If myRs.Fields("Item Type").Value = "TABLE" Then
.InitDir = CatalogPath
Else
.InitDir = CatalogPath & myRs.Fields("directory").Value
.ShowOpen
BrowseFileName = .Filename
End With
If BrowseFileName = "*.dwg" Then 'if there is not a valid file name then
the cancel button was pressed
BrowseFile = False
Exit Sub 'no further action required
Else
DwgVer = ChkVer(BrowseFileName) 'check the drawing version
With frmCatalog.ocxVView
If DwgVer <> "R12" Then
.src = BrowseFileName
.Visible = True
frmCatalog.imgAirGageLogo.Visible = False
End With
frmCatalog.cmdInsert.Enabled = True 'enable the insert button
BrowseFile = True
lstPartNum.Clear
End Sub
You will have to make a reference to the comdlg32.ocx in your project and
then place the control on your form. Make the visible property false so
that the user will not see it.
Set the initial directory property prior to showing the dialog so that it
comes up in the same directory as your active drawing
ComDlg.InitialDir = Thisdrawing.Path 'ComDlg is what I named the
control for this project.
Make sure you Name it what you want it to be.
From here you can browse all over your system. After you hit the ok button,
you can retrieve the file name(s) from the FileName property. If you have
the multilpeSelect property set to true, you may have to parse thru the
string to seperate the file names.
I hope this is of some help.
Mark Smith
Air Gage Co.
masmith@airgage.com
Message 7 of 12
Gary have you looked at the dir function? I built a win16 type of file list
using it (no common dialog). Works pretty good.
phix
Mark Smith wrote in message
news:ef29a66.4@WebX.SaUCah8kaAW...
> Gary,
for
> a file
> know that
> access the
> .DefaultExt = "dwg"
> Else
> End If
> .ShowOpen
> End With
then
> BrowseFile = False
> Else
> .Visible = True
> End If
> End With
> BrowseFile = True
> lstPartNum.Clear
> End If
> End Sub
button,
> Mark Smith
> Air Gage Co.
> masmith@airgage.com
Message 8 of 12
Thanks Everyone. I can use all of these samples in one place or another.
John, I managed to get the code you posted running and printing to debug.
Looks like just what the doctor ordered. Now I don't have to put a password
on the file so no one can se my feeble and "Micky Mouse" attempt.
Thanks again,
Gary
Message 9 of 12
The Common Dialog Control is not usable in VBA unless the local machine also
has a Microsoft development product like VB installed on it.
Attitudes are contagious. Is yours worth catching?
http://www.acadx.com
news:ef29a66.0@WebX.SaUCah8kaAW...
dialog
> box.
Message 10 of 12
Thanks Frank. My machine is the only one with VB6 installed. I will have to
be more careful in choosing controls in the future.
Gary
Message 11 of 12
For an excellent replacement that is free, redistributable and comes with
the source code take a look at the CommonDialog Replacement DLL over at
http://vbaccelerator.com
I actually refer it to the CommonDialog Control since it offers support for
dialog positioning, a built-in method for parsing multiple file selections,
the ability to use diaolg templates and much, much more. While you're there,
be sure to look around. The author has some amazing controls and dlls and
they're all free!
news:ef29a66.8@WebX.SaUCah8kaAW...
to
> Gary
Message 12 of 12
Thanks for the tip Frank, I'll check it out.
Gary
