extract boundary of hatch
Message 1 of 35
ive found an autolisp to extract the boundary of a hatch
http://www.spaug.org/Public_Files/AutoLISP/HatchB.Zip
but in VBA it cant be done if boundary was deleted
hatchObj.GetLoopAt J, loopObjs
this only works with existing objects used as loops/boundary
so, is there any way to extract DXF codes/lists of an object and work in VBA with them?
i dont want to work with LISP, is a very extrange language for me
Replies (34)
Message 21 of 35
aaahhhhhh, now ive got problems with ErrHandler, is not defined, is it a private type, a err object?
this is the way im trying to test your class
Dim Ci_Hatch As New Ci_Hatch
Dim oObject As AcadObject
Dim FSO As FileSystemObject
Set FSO = New FileSystemObject
Dim DXFMatches As MatchCollection
Dim DXFMatch As Match
Dim Rexp As New RegExp
Dim DXFstr As String
Dim i As Integer
Dim submatch As Variant
DXFstr = FSO.GetFile("C:\puntos.dxf").OpenAsTextStream.ReadAll
Rexp.Global = True
Rexp.MultiLine = True
Rexp.IgnoreCase = True
Rexp.Pattern = "\n\s\s0\r\n((HATCH)[A-Z\d]*)\r\n\s\s5\r\n([\dA-F]*)(.*[\r\n](?! 10))*330\r\n([\dA-F]*)(.*[\r\n](?! 10))*((.*[\r\n](?! 0))*)"
Set DXFMatches = Rexp.Execute(DXFstr)
If Not DXFMatches.COUNT = 0 Then
For Each DXFMatch In DXFMatches
If Not DXFMatch.SubMatches.COUNT = 0 Then
For Each submatch In DXFMatch.SubMatches
If IsNumeric(submatch) Then Set oObject = ThisDrawing.HandleToObject(CStr(submatch))
Next submatch
MsgBox DXFMatch.value
Ci_Hatch.Read oObject, DXFMatch.value
Next DXFMatch
Message 22 of 35
the handle string is not always a numeric value, so this will not work sometimes
so, is the handle string on a particular position of the submatches collection?
Message 23 of 35
Yes... Position (1)
And jusyt remove the ErrorHandler lines.... you dont need them....
Message 24 of 35
it gimme Object variable or With block variable not set (Error 91) in hatchloop buildreflist, and them gives error on other subs of hatchloop
the test seems to be OK
Dim oObjectHatch As AcadObject
Dim i As Integer
Dim sHatch As String, sHandle As String
Dim iCountMatch As Long, iCountSubMatch As Long
DXFstr = FSO.GetFile("C:\hatch.dxf").OpenAsTextStream.ReadAll
Rexp.Global = True
iCountMatch = 0
iCountSubMatch = 0
Debug.Print "Match " & iCountMatch & ", SubMatch " & iCountSubMatch & ":" & submatch
iCountSubMatch = iCountSubMatch + 1
Next submatch
sHandle = CStr(DXFMatch.SubMatches(2))
Set oObjectHatch = ThisDrawing.HandleToObject(sHandle)
If Not (TypeName(oObjectHatch) = "IAcadHatch2" Or TypeName(oObjectHatch) = "IAcadHatch") Then
MsgBox "Failed to handle object": Exit Sub
sHatch = CStr(DXFMatch.value)
Ci_Hatch.Read oObjectHatch, sHatch
iCountMatch = iCountMatch + 1
Next DXFMatch
ive added Microsoft XML, v4.0 as reference, testing with a simple non associative hatch using a polyline as outerloop
Message 25 of 35
The buildRefList is not necessary. Take a look at the Read and CreateBoundaries functions... if its not called by one of thoses functions, you don't need it.
Actualy in the Read, just remove all lines between the 2 ('---------------------------Ref list). They were used for other purpuse.
Message 26 of 35
this starts to work, but in this example the polyline coordinates (boundary created) are not the coordinates of the polyline of hatch
the hatch is the little one on the left-bottom corner of the drawing (hatch.dxf)
maybe a decimal symbol problem? how could i read the full xml document? i would like to check the data organization of xml for debuggin
if anyone wanna test it must change this kind of lines
Set ArcObj = ThisDrawing.Blocks(mSpaceType).AddArc(Centre, mRadius, mStartAngle, mEndAngle)
to
Set ArcObj = ThisDrawing.ModelSpace.AddArc(Centre, mRadius, mStartAngle, mEndAngle)
i still didnt change all of them
Message 27 of 35
Did you give it the right DXF block? My best guess is that you did not give it the right DXF block for the entity that you passed. (not the same handle?). I think its the only possibility.
If you want, just post your project and I'll fix it in about 5 min. (I have been working with these classes for the past year, I know them real well.......!
And thats right.... forgot to tell you that you must use the SpaceType property to specify the container where you want those boundaries to be created (name of a block, or "*Model_Space"....).
Message 28 of 35
Ok... something is wrong here.
This works well. Just remove the big Polyline, then Zoom Extent and you will see your hatch and its contour around it. Perfect.
I realy didn't change anything in your code and it worked perfectly. And why is that big polyline doing there?
Anyway, this works.
Message 29 of 35
that big polyline is the boundary created when i run the vba
so, if it works for you, now im sure it must be a question about decimal symbol in the data flow from dxf-xml-autocad
you know, sometimes 12,546589 finally turn 12546589, so thats why this big polyline is there, it should be the little polyline inside the hatch
ill try to change decimal symbol and test again
Message 30 of 35
No, sorry, thats not it....
Just try it. Delete that big polyline and execute the code. The big polyline wont reapere..... or if it is, the code is different than what you gave me.
Message 31 of 35
Here are the exact steps I took:
1) Load the drawing and VBA project
2) Erase the big polyline
3) Zoom extents
4) Change the path of the DXF file in the sub test in the Module
5) Execute
That works perfectly..... let me know.
Message 32 of 35
test this:
Control Panel/Regional and
Languages Options/Customize: English (USA)
then it works perfect
now change to
Languages Options/Customize: Español (España)
try again and you will see the big polyline
in DDCH server scripting, when working with dates, we use to fix this using 'setlocale', but dont know if this function is available in VBA
also dont know where the decimal symbol change, if it is in dxf or xml, thats why i wanted to read the xml
Message 33 of 35
Found it!!!
You were right!
The problem is that AutoCAd does not follow the system's format. But since I'm going "back door", I end up being affected by the computer's configs.
Solution:
In Ci_Hatch-ReadBoundaries, after the 3 Replace statements, add this one:
DXFBlock = Replace(DXFBlock, ".", ",")
And its fixed.......!
Message 34 of 35
ah, ok, i have fixed it this way
LCID = GetSystemDefaultLCID
sDecimalSep = GetUserLocaleInfo(LCID, LOCALE_SDECIMAL)
If Not sDecimalSep = "." Then Call SetLocaleInfo(LCID, LOCALE_SDECIMAL, ".")
the full code with GetLocaleInfo,SetLocaleInfo functions are in the attached file
now i want to automatize all process in VBA:
1.- select the hatchs in a DWG to recover boundaries
2.-open a new drawing and copy the hatchs selection on it
3.-save the new drawing as dxf
4.- read the dxf and operate over the original DWG
ill post when having something done (or may when having a question, hehe)
thanks again
Message 35 of 35
this is working perfectly when selecting one hatch, test it
it makes the 4 operations listed in my previous post
but when selecting 2 hatchs appears the error: index out of range in Ci_Hatch.Read
any idea?
