Export to EPS
Export to EPS
Export to EPS
Hi All,
I have to convert dwg files to svg format. For that I have export the dwg file to eps format. Then choose "save as svg" option in Illustrator. In the new svg file the lines and circles are missing. Please help me in this topic.
Thanks and Regards,
Anjana
Most likely the lines and circles are there but so thin as to be invisible.
Exporting to EPS from the File menu or its equivalent PSOUT command is very
buggy and difficult to control. The best way to export to EPS is to set up
a PostScript plotter and plot to a file.
jrf
Autodesk Discussion Group Facilitator
Please do not email questions unless you wish to hire my services
On Tue, 16 Oct 2007 09:50:22 +0000, anjanact wrote:
> Hi All,
topic.
> Thanks and Regards,
> Anjana
In the eps file everything is coming properly. properly I can export it to png,jpg etc also. The problem occurs while saving it as svg format.
If the EPS is fine in illustrator then it is not an AutoCAD problem.
Thanks.....
Anjana
